Because my fan isnt coming on even when just sat in my driveway
Fan works pefectly when you disconnect sensor.
KyzarVS wrote:
Does the fan come on with just the ignition? For example if you go on a run to get the engine hot and then stop, kill the engine and then turn the ignition back on(so the dash lights are on), does the fan then come in as normal?
