I know the stock temp gauge is poo, so I'd like to fit another gauge, which would be easier / better out of oil temp & coolant temp?
If you were going to fit one or the other which would it be?
Reason I want one is I find if i wait for temp gauge to rise to where it stops, just below half way (TRD thermostat) the car doesn't boost properly (stutters & feels like misfiring). If i wait another 5 mins then it boosts away all fine, i'd prefere to glance at a guage to know its ready & up to temp rather than find out by flooring it and have it misfiring.
Temperature gauge
Temperature gauge
'97 mk1 Mazda Eunos Turbo track car with 260bhp/ton - soon more as Chris Wilsons going to build me an engine over the winter ) .
Re: Temperature gauge
oil temp would be more inportant than water temp.
IMO, you want to know when your oil is up to optimum temp before you give it some
HTH
HTH
I also believe that if the engine is cold, the boost is retarded by the ECU
VSV is disabled though, so boost is set at 12 psi with g-valve.
