[FINALIZED] Genuine Raybrigs - Plug and Play System
Parts for the Mk2 MR2 only (excluding bodywork and wheels/tyres)
androo007
Post by androo007 »
Hi guys,
I have a genuine, great condition Raybrig setup for sale, complete with headlamps, surround and all wiring needed.
It's a plug and play system, no hassle or dodgy hookups needed.
As you can see almost in as-new condition!
£100. Any questions, just ask.
shinny
Re: [FINALIZED] Genuine Raybrigs - Plug and Play System
Post by shinny »
I'm curious, what does the extra wiring do differently to the stock wiring? :-k
androo007
Post by androo007 »
You know what Shinny, I'm not sure! I've never had a pair just assumed it was part of the package.
It uses the stock headlight grounds, and other end links to battery positive.
I assumed being higher power lights they needed higher quality cables (they are beefy!) and being a complete 1 piece setup not homemade, i thought part of the kit! Is that not normally the case?
tiff_lee
Post by tiff_lee »
Any halogen headlight setup would actually benefit from a dedicated high quality loom like that.
The voltage drop induced by stock wiring (on many cars not just 2's) has a significant effect on light output, there used to be a good graph on the osram site plotting halogen light output vs input voltage but I can't find it.
Best I can do is the graph found in this thread
http://www.candlepowerforums.com/vb/sho ... r-lighting
androo007
Post by androo007 »
Thanks tiff_Lee, that would explain it! The wiring loom looks to be made by SS Limited, and is definitely MR2 specific, so i thought it was standard with the kit
Feedback Bot
Post by Feedback Bot »
Return to “Mk2”
