Its all installed and in one piece it just seems to by a wiring issue.
abovetherim wrote:Check you are getting the required power at both feeds.Yes 2 live feeds.
1 perm.
Via the amp behind passenger side panel behind seat
(iirc pink wire) and switched live from stereo
Mike wrote:abovetherim wrote:Check you are getting the required power at both feeds.Yes 2 live feeds.
1 perm.
I bet thats it.A previous owner
(for some unknown reason) has bypassed the standard amp driven system and wired a set of 6x9s straight to the head unit.
That'll be it.
Given how difficult the standard system is known to be to fiddle with I guess I wont be having a working electric aerial.
