ok ROADTRIP
got there and it was as bad as i was expecting, terrible
get it home, taxed and insured it and took it for a quick test drive
oh dear, the clutch is slipping.
took the clutch out, heavily worn new clutch in adjusted the pedal correctly, all is well.
before driving it again i decided to stick a full polybush kit on it and new droplinks.
whilst doing this i had a prod round underneath and several more issues became evident.
handbrake cable was snapped
rear sills where full of newspaper and filler.
brake caliper bolts where only finger tight.
oil was 2.5 liters overfilled!!!!!!!
the electrics where dangerous.
that and all the cosmetic issues meant this was getting expensive fast.
so the jobs completed so far
fitted a spare pair of bucket seats i had kicking about after making new mounts that are actually strong enough.
new clutch
polybushed throughout
new drop links
serviced brakes
new handbrake cables
flushed cooling system and refilled with correct coolant mix
welded up the sills
sorted wiring or at least some of it.
and im sure there's loads left to do.
so errrm, hi, and ill keep this thread updated with the trial and tribulations of fixing a morons castoff.
