Hi.
I've just bought my second mk1 MR2 after a brief affair with a Triumph Spitfire.
This time I've gone for a T-Bar and spent several weeks searching the country for the best I could find.
The car is immaculate, but there are a few issues that I need some help with.
Firstly, the engine is pinking, especialy when it's cold.
I've found it happens much less with a lower-octane fuel, but it still sounds a bit like a beetle.
I've tried lead-replacement additive, but this didn't make much difference.
Has anyone else experienced this same problem? The car has been superchipped, which could be significant I guess.
Secondly, I need some engine mounts, but I've been told they're very expensive
(like most Toyota parts).
Does anyone know of any cheaper replacements? Also, I need a new cooling fan control unit.
Mine got wet, so I took it apart to dry it, and broke it in the process!
Lastly, much to my frustration, I discovered on the way home from collecting the car that it's started popping out of fifth gear occasionally.
When this gets worse, will I have to replace/recondition the gearbox, or is there a cheaper option?
Any advice would be very gratefully received.
I'll try to get around to posting some photos on this site,
'cos she's a beauty!
