I've had this car for a number of years and transformed it from a forged 3s build into a monster 5SGTE build which is where it is today.
No expense has been spared in this build, and all work has been done professionally by the best in the business.
The car is currently sitting on
Like so many others end up, my journey is now at an end.
I can't express clearly enough
- 1998Â Genuine JDM Rev 4 Turbo
104,000(mixed miles/kms)
HPI Clear, NO previous accidents
Rust Free, immaculate outside and underside.
- 5SGTE Late square edged block, with the square/diamond plugs.
This is strongly reputed as THE strongest of all the 5S blocks.
Block has been thermally treated to provide additional strength
EFR7670-105Â Twinscroll Turbo
Carrillo Con Rods.
Carrillo Pistons.
Chico Raceworks Crank
Rev 4 3SGTE ported and flowed head
Oversized Manley racing valves
272 Kelford Cams
Genuine HKS Cam Gears
Injector Dynamics ID1050X Injectors
Fully electronic Fly By Wire(FBW) Throttle setup
Full sequential timing COP setup(not the half ar$ed method we see)
- Precision PT1001 Chargecooler System
- this is THE best chargecooler unit on the market.
- Full-Race Motorsports twinscroll manifold
Twin 38mm watercooled wastegates
Custom built downpipe from 3.5" reducing down to 3"
Pheonix Power Pro Departure I exhaust- not the II
- SUPER rare
- Standard E153 gearbox that's just been refreshed with new gears etc.
Getting hard to find!
Compclutch twinplate clutch
TRD Quickshift
- Tein Monoflex Coilovers
Toms pillow ball Top Mounts
Cusco rear strut bar
Uprated Front& Rear suspension arms
Uprated CV joints etc all fine to handle the power
- Boost control via the air injectors, which are motorsport grade
Syvecs ECU with custom built loom.Multiple maps available via rotary switch located behind gearstick.
4 maps available from 1bar to 2.2 bar (500-700hp)
- Toms Side skirts
Front Lip
Genuine BBS LM Alloys, superb fitment.
R888 tyres
- Recaro Pole Position seats
This car is a serious advert, and i'm only interested in serious buyers.
![Image](https://iili.io/JgY71V.jpg)
![Image](https://iili.io/JgY5qQ.jpg)
![Image](https://iili.io/JgYYrB.jpg)
