want to keep the standard look?
cheers
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
wikiz wrote:I fitted these 6.5's to mine.I made up a 12mm thick mdf spacer, screwed it to the door using existing holes and screwed the speaker to the spacer.
Attempted to put on the door card and it didnt go on fully..
.so I trimmed away some of the inside of the door card as I also wanted it to look standard.
From the outside it just looks like nothing has changed but takes a little more time, however well worth upgrading to 6.5's imo
