i have a lightened flywheel on my n/a and a performance clutch, both brought from funky product.
great service and great products
The throttle response and pick up of the revs is alot better now fitted which helps the 3sge engines as they have all the power in the higher rpm range espically above 5000 rpm
The lauching is a bit wierd now as the flywheel is lighter and doesn't have the torque to really wheel spin at the start of a race but the launch is massive lunge if u keep the car at around 5000rpm and then drop the clutch
