which wires refer to this post???
http://www.imoc.co.uk/forums/viewtopic. ... 9b75098d8b
how do i fit boost gauge?? where are the wires under dash???
Re: how do i fit boost gauge?? where are the wires under dash???
by looking at the diagram
Grey wire is ur Signal wire
the T piece go in the Engine and tap into existing boost line
than to the recever unit (link to the grey wire)
+12v key is the acc wire either taking from stereo one(easier)
ground any
+12v dash lighting (for back light) I will take it from Cigrate lighting bit (for light at night) or just ACC (on all the time)
but depend where and how you mounted it, the hose dont look like long enough
I hope it help
ground any
I hope it help
SFLee wrote:by looking at the diagram
ground any
I hope it help
how far has the hose got to reach????
(its a electricallt boost gauge by the way).
also, where can i find some?? i measured the thickness of the tube i presently have, its 8mm wide, with a 4mm wode hole.
