Running to much boost
after having my engine light come on with fault 34 i reset the ECU and checked the boost presure and i'm running 1.6 bar of boost and as far as i know the car is stock could it be a faulty vsv?
Re: Running to much boost
You've definately got some problem there. Check all the pipe work, like the pipe from the turbo to the actuator. Be very carefull as that much boost on a rev1 will quickly end in tears.
1.6 Bar on a rev 1?!?!?!
1.03 Bar is 15 PSI and should be the safe boost limit run on a rev 1 with the FCD set at 16 PSI
Hope this helps
Craig
Hope this helps
Craig
You should have hit fuel cut before you hit 1.6 bar.??
My rev 1 had a split in the hose between the turbo and actuator and did this but my fcd was set to 15.5 psi so I never went as high as 1.6 bar.
I bet it flew
Zero
I bet it flew
Zero
