Following on from my other thread re the misfire.
I replaced the fuel pump with a walbro off a member on here a few months back and thought it was noisy compared to oem but assumed it was normal.
It drove fine once this was changed.
It makes a high pitched whine continuously however the noise changes tone when the steering is turned or lights on but is still quite noticeable,.
Can even hear it outside the car.
My mechanic
/ friend seems to think this may be the issue of the misfire as the car splutters when under load going through boost.
Seems to think its running rich.
Not too bad when cold start but after 10-15 mins gets bad and after 20 mins of driving it will struggle to get over 20mph
