If someone from scotland wants any bodykit parts then i may be able to arrange free drop off (all the cities anyway). Border bumper can't be posted due to size so will be looking for a scottish buyer only.
picture of dial, speedo, head unit
https://www.youtube.com/watch?v=1HNbs5U5q2A
Due to several reasons i have a rev 3 turbo being broken. One of which is rot, the sills are paper thin, the clutch needed replaced and body panels had rust or different colourings and scratches.
I am not sure on prices so open to offers on some items, pictures on request (weekend onwards) as i am working solid until saturday so i can't post anything until next monday at the eraliest either.
Rev 3 speedo with white surround and steff derner delimiter. sold
Uprated back and front engine mounts �70 posted sold
walbro fuel pump sold
Mallory fuel pressure reg. with gauge and all pipes and fixtures. sold
Bride bucket seats with genuine bride rails �700 sold
Flat bottom steering wheel with removable boss �120
Blue led lit heater control x2 �40 posted each.
6 x 9 speakers in boxes for behind seats sold
under body toms ?? strut sold
rev 3 brakes, front and rear, come with uprated brake lines sold
rev 3 drilled discs, both front and rear. sold
Sard dump valve �45 sold
Helix braded brake lines �35 x 4
k and n air filter plus 3" fitting tube �45
Blitz stainless steel air filter and 4" piping sold
Hks dumpvalve �80 sold
Rev 3 distributor/rotor/cap �45
Rev 3 turbo ignition leads �45 plus post
3 60mm analogue and digital dials built into a worse for wear centre pod. oil pressure, boost pressure and oil temp. 4th gauge in own pod that sits beside ashtray (water temp). all sensors, wiring and sanwich plate included. also this comes with a turbo timer and button engine start, all built into the centre consol, wiring for turbo timer and the auto start button have a plug and play loom. �300 ono
Subframe in good condition sold
rev 3 turbo loom �65 sold
front hubs with good bearings �25 sold
steering rack �90 plus post
blistein suspension with lowering springs. �180 posted sold
white coloured centre console and door cards and white centres and centre box (white)
sold
cobra cat 1 alarm with sensors, lights, remotes. all wiring comes with attached looms and pictures to aid fitting, cat 1 imobolisor as well. �65
two doors in reasoanble condition with windows etc. included. �60 plus post each sold
rev 3 rear lights, they have a dark tint, white centre with all fittings. twin filiment bulbs for both breaking and side lights. reversing and fog lights in centre panel. sold
18" wheels (need some attention) with good condition(5mm+)215 eagle f1 tyres on the front and brand new 275 michelin sport 4s on the back. rears come with 10 mm spacers. Wide arches will come with this kit that are a perfect fit. also comes with locking wheel nuts x 20. Border rear spats, single side vents, rear spoiler and hub spacers. �600-�700 worth of tyres on these wheels, open to offers. This is pretty much a plug and play wide arch kit for a mr2, see above pictures. �1200 plus postsold
greedy/trust gearknob and uprated gaitor (this was sold but the buyer hasn't paid for it so back up for grabs). �50 plus post
I have an almost new blutooth kenwood double din headunit.(about 15-20 hours use) sold
Sony bluetooth single din �35 plus post
border front bumper some cracks on the bottom, mesh grill and aluminum undertray, �140sold
border side skirts �100 sold
rear quarter windows �30sold
very large rear wing �140
sold
aniversary sills �40 sold albeit for almost half of what i advertised them for , need to pay more attention, lol
sold
Rev 3 turbo lsd gearbox, runs fine but 4th gear came out of gear when i was resting my hand on the gearstick, �150 plus post, all other gears perfect. sold
floor carpet, turbo mats, etc. offers
handbrake cables �20
Under trays, x-brace, battery in good condition (can drop off scotland), steering column, locks with working key etc.
rev 3 turbo knock sensor �50 postedsold
trd oil cap sold
alternator �50 plus post
starter motor �25 plus post
4 wire o2 sensor �45 plus post
Helix lightened flywheel �100 postedsold
f40 engine lid copy (sold)
front quad headlights �150sold
Front clear sidelights and indicator lights �30 plus post (slight chip in one refector) sold
Doors �50 each plus post (come with windows etc.) sold
Lock set with key x 2 (includes boot, doors and steering column �100
Ignitor �70
electric speed sensor �55sold
inlet temp sensor �20
215/35/17 tyres x 2 (6mm tread) �80 postedsold
Throttle body and sensors �50
Rev 3 turbo inlet manifold �45 sold
Probably missed loads of things so try me,
Engine/turbo/ecu/gearbox/shafts/injectors/boost controller sold
Breaking Highly modified rev 3 turbo
Re: Breaking Highly modified rev 3 turbo
Sad day hope you get what you want from it Martin
androo007 wrote:Sad day hope you get what you want from it Martin
The sills were hidden by the skirts, they had holes i could fit my fist into , clutch was shot, turbo would have been needing a rebuild soon and the spray job was done by back street cowboys, it was breaking, cracking and rust was coming through on almost every panel. front bumper went a shade of yellow, funny thing is that i kept it off road over the last two winters and this is what happened, that was therefore a total waste of time
I won't get back what i would like because of the above issues but they forced my hand in choosing to break rather than selling, this will probably be my last mr2
How would you value the wheels and wide arch kit ? 10mm spacers, 5mm+ eagle f1s and brand new 275 pro sport 4 tyres on the rear. 20 locking nuts with two different keys ??? wide arches cut and fitted to perfection ??
I don't know buddy I'm afraid I am rubbish with wheels and body side of things
After gear change cables mate posted
simpson_eh wrote:After gear change cables mate posted
Sorry, sold
oh no... why break it...
i m intressted in some parts... where you based?
Edit:
any pics from Bride seats? Hubs are with ABS? dump valve with adapter?
intressted list:
Uprated fuel pump £50
Bride bucket seats with genuine bride rails £700 posted ono
under body toms ?? strut. ££ ?
Sard dump valve £45
Hks dumpvalve £80
all hubs with good bearings £25 each plus post
blistein suspension with lowering springs. £180 posted
greedy/trust gearknob and uprated gaitor (this was sold but the buyer hasn't paid for it so back up for grabs). £50 plus post
single vent side vents
border ?? side skirts
aniversary sills
trd oil cap
alternator £50 plus post
4 wire o2 sensor
Edit:
intressted list:
Sard dump valve £45
Hks dumpvalve £80
aniversary sills
trd oil cap
4 wire o2 sensor
puku wrote:oh no... why break it...
Edit:
intressted list:
Sard dump valve £45
Hks dumpvalve £80
aniversary sills
trd oil cap
4 wire o2 sensor
https://imgur.com/9mYvCIn , plus............
turbo needing a rebuild, clutch needing replaced plus i bought a car that's maybe well slower but much more me
bride seats are provisionally sold, hubs are non abs, i have someone interested in the fuel pump and possibly side skirts. Been a busy week so will instigate contact and know one way or another by sunday. sills and trd cap also maybe gone, everything else still up for grabs...
Let me sort out what's what and i will send you a pm with what's still available by sunday evening
Just PM'd re the doors
I'm looking for a pair of lsd hubs and lsd passenger side drive shaft
dylan5084 wrote:I'm looking for a pair of lsd hubs and lsd passenger side drive shaft
Sorry, driveshafts have been sold and all the hubs are non-abs
non abs is fine, as long as there lsd ?
hi, do you have the alternator and if so what type of plug is it?
raptor95GTS wrote:hi, do you have the alternator and if so what type of plug is it?
I have a few alternators, not sure of plug. Came off rev2,rev3 and rev4 turbos if that helps. I could have a look tomorrow when I am getting the rear hubs out of the shed. What plug type are you looking for ?
I'm in Glasgow this Tuesday so if you get back to me in time and are central I can drop it off maybe ??
hi, it's the oval plug type with part number 27060-74500. I'm in livingston this week as well as Glasgow so either suits me
raptor95GTS wrote:hi, it's the oval plug type with part number 27060-74500. I'm in livingston this week as well as Glasgow so either suits me
Any Good ?
Such a shame Martin.
Onto vulture mode, do you still have the clutch slave cylinder?
LimeyMk1 wrote:Such a shame Martin.
HaHa, maybe, can you send me a picture of the exact part you want to avoid any confusion ?
