[Mk2] [Turbo] Lost key!
nevvo
Post by nevvo »
Guys, long story short my only key has disappeared and I'm struggling for the cheapest solution! It's a 96 turbo so assume it has an immobiliser chip inside (making it more costly: (). I have a Clifford alarm and have a spare fob for that so no issues there.
Can anyone recommend who to turn to? Guessing Mr T will have my eyes out...?
I'm in Warwickshire if anyone knows of anybody local.
Thanks,
Useless moron.
thomp1983
Re: [Mk2] [Turbo] Lost key!
Post by thomp1983 »
Im not aware of any mk2 having transponder keys coded to them. As for the easiest solution that depends on your diy level and how brutal your willing to be.
to remove the barrel itself requires the key turning just before the first click and pushing it a spring loaded part on the barrel to release it. I can't remember off hand if theres enough access to drill it. A locksmith may be able to pick it and get the barrel out but it's costly. Locks aren't that heavy duty id be fairly confident you could hammer into the lock a hardened piece of steel or a chisel and force the lock to turn. Or you can drill it with decent bits until eithe lock mechanism gives up or you drill past the retaining bit.
Personally id look at drilling the spring loaded part im sure it's accessible and shouldn't give much hassle to a decent bit then the barrel will just pull out
It's the dark bit in the middle you'd want to drill through
nevvo
Post by nevvo »
You've put my mind at ease a little there chap!
Is anyone able to confirm that Mk2s weren't coded with a transponder? Would make my life a hell of a lot easier if that's the case!
Mikey637
Post by Mikey637 »
My uk rev5 is transponder
nevvo
Post by nevvo »
I'm reading loads of conflicting information...
Did any JDM imports come with a transponder key? I have no buttons etc on my key so I'm really not sure.
thomp1983
Post by thomp1983 »
are you sure mikey? im pretty sure my stepdads old rev5 wasn't, the remote keyfob is programmed to the car but there was no chip in the key as far as i know, the easy way to check is just remove the surrounds from the steering column if your key is coded to the car there will be a pickup ring around the ignition barrel (looks like a plastic loop with wires to it)
killerferret666
Post by killerferret666 »
Rev2 import and I have no transponder as I got a new key cut.
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
nevvo
Post by nevvo »
Spoke to mr2 Ben and the chap told me that because mine is a very late rev 3 (only 500 or so off being a rev 4) it's not got a chip in the key. So I'm going to go for it, door lock coming out tomorrow night to find the number.
Having said that, Toyota told me that it did have a chip and that if need a new lock set (£1200 +VAT) and door module (I didn't hang around for the price of that).
I've been given a quote of £170 if it is a chip key and the bloke needs to come to me. Willing to chance it with mr2 Ben first though!
Draven
Post by Draven »
Rev 3 turbo no transponder on my key.
thomp1983
Post by thomp1983 »
Did this get sorted?
acf8181
Post by acf8181 »
Buy second had lock set off someone on here is prob cheapest option.
Not sure how ignition lock is installed in MR2's but when i had a lost key issue on my old scooby i got a lock set with the entire steering column, and switched that as was easier (not a breeze mind) i felt.
....Lets just say since then i have about a million spare keys made for every car!!
2mad
Post by 2mad »
Draven wrote:Rev 3 turbo no transponder on my key.
Nope .. me nether :?:
Hope you sorted it .. only skimmed posts #-o
Draven
Post by Draven »
I've got a barrel and a key if required. I'm guessing it was all sorted.
SonicSW20
Post by SonicSW20 »
thomp1983 wrote:are you sure mikey? im pretty sure my stepdads old rev5 wasn't, the remote keyfob is programmed to the car but there was no chip in the key as far as i know, the easy way to check is just remove the surrounds from the steering column if your key is coded to the car there will be a pickup ring around the ignition barrel (looks like a plastic loop with wires to it)
Both my Rev4 and Rev5 had an immobiliser. Key looks like this:
Draven
Post by Draven »
Wierd my rev3 has a button the side of the key for the central locking but no immobiliser.
I'm guessing it was an option?
SonicSW20
Post by SonicSW20 »
Draven wrote:Wierd my rev3 has a button the side of the key for the central locking but no immobiliser.
Standard on UK Rev4/Rev5 as far as I am aware. They have the remote locking on a separate fob - so 90's.
The only Rev3 I've been to see had the metal key. It was a shed though so it may have been a replacement.
Harry Cy
Post by Harry Cy »
Same problem here mate mine is a rev1 turbo with fob and imobiliser small plastic with a red flashing light. So what did you do??
Peter Gidden
Post by Peter Gidden »
If the ignition lock has a green lit ring around it, there is no transponder.
If it doesn't have a green ring, it has a transponder.
The coil for the transponder key replaces the green illumination.
Harry Cy
Post by Harry Cy »
You are a life saver. I got green lid 😅
But it had central locking on the key and that got me confused. Thank you
RyanWilson
Post by RyanWilson »
It's very useful post !!
Return to “ICE and Security”
