Hi
To start of with you ONLY need three wires.
They are
12V+ Constant
12V+ IGN
GND
These will give your HU a power supply.
This means that you can switch on the HU and see if it works.
Then you need the following connections.
Speaker wires.
After that, the amp switch wire needs to be connected to your HU, so when the HU comes on so will your amp and also your aerial wire needs to be connected too.
I think on the Toyota HU the aerial pops up ONLY when the radio function is enabled and not before.
Apart from that there are a few other wires like the
+iLL
thats for the illumination on the HU
--- for the display on HU etc.
Do you have a multimeter at hand.
You really need to sort out the wires first and i would start with the Power supply.
If you are trying pot luck with the wires you can blow fuses, amps and even the HU.
so be warned
Apart from that, its a straight forward process.
until you come to my cars setup
.lol
