Ive been looking for how tos, on fitting front and rear fog lights on an import prefacelift, i cant find anything am i missing something ?
My car has the facelift rear lights ,and a bodykit front bumper ,ive read that the early cars had no wiring for front fogs ,but my import has the switch and fuse for front fogs ,so i assume imports differed from UK in this respect
any pointers anyone ?
Re: fog lights on an import
Only the FE never had the front fog lights. Imports never had factory fitted rear fog lights.
Front fog light looms have probably been cut off.
Sorry this was meant to be in the MK3 section
could someone move this post please
BLZ-8027 wrote:Sorry this was meant to be in the MK3 section
My fault, i reported it..
Your profile shows a "1990 Toyota MR2 Mk2 NA Rev1" so i assumed you posted wrong forum.
Peter Gidden - SBITS wrote:BLZ-8027 wrote:Sorry this was meant to be in the MK3 section
I sold that on monday ,not got round to updating yet
- IMOC Committee
Moved it back
BLZ-8027 wrote:Ive been looking for how tos, on fitting front and rear fog lights on an import prefacelift, i cant find anything am i missing something ?
my uk preface never had front fog wires but if you do have them then stick a volt meter on them and get someone to turn the fogs on if you get power then you only need stick lights on the end. as for rear fog doesn't it require it to be fitted before you can get your hands on the motor?
rbuckingham wrote:BLZ-8027 wrote:Ive been looking for how tos, on fitting front and rear fog lights on an import prefacelift, i cant find anything am i missing something ?
I dont have any wires anywhere ,but i do have the switch, and the fuse is in place for foglights in the fusebox ,guess the wire has been cut away
Rear fogs are needed on import for the uk and MOT ,so it must have had them before somewhere ,its had facelift rear uk lights fitted ,but with import looms, so the bulb holders sand wiring are all a mis match
Ok then all I can say is you will have to trace the wires from the switch to find out where its going. Can't really help much more than that im afraid without the car being in front of me, unless you fancy a drive down to me I don't mind helping
rbuckingham wrote:Ok then all I can say is you will have to trace the wires from the switch to find out where its going. Can't really help much more than that im afraid without the car being in front of me, unless you fancy a drive down to me I don't mind helping
Thanks for the offer ,its not desperate at present but i might take you up on it later ,ive got issues with the roof to look at as well
