hello there, i have a 1995 Toyota MR2 GT 2ltr, its failed on emissions. The results show the following.
Fast Idle test :
CO - limit <=0.03% vol, actual=5.86% vol;
HC - limit = 200ppm vol, actual = 208ppm vol;
lambda - limit=0.970-1.030, actual=0.843.
Second Fast Ide Test :
CO - limit<=0.30 %vol, actual=6.49 %vol;
HC - limit<=200ppm vol, actual=263ppm vol;
lambda - limit=0.970-1.030, actual=0.820.
Natual Idle Test :
CO - limit<=0.50 %vol, actual=5.71 %vol.
i would really appreciate some advice on what part might be at fault before i start spending money on fixing it up.
cheers, Jack.
help MOT emissions
Re: help MOT emissions
Hi Jack mine failed the other day too but I got it passed on the re-test. All I done was put some cleaner in the car and then drove it hard, but under the speed limit, before taking it back to the garage so it was warm
Our Discounts/Specials:
http://www.carbenfibrecreations.co.uk/specials
This is the Mk3 part of IMOC
