steven63 wrote:The stock ct26 will never hold 15psi to the red line but fitting a stronger actuator will make it hold 15psi to 5,500rpm
Ryan S wrote:steven63 wrote:The stock ct26 will never hold 15psi to the red line but fitting a stronger actuator will make it hold 15psi to 5,500rpm
That was always my understanding of it too, Was just reading some guy in the states holds 15psi till redline no issues.Although it's not important i guess.
It's only gonna be on for a short time.
Gazza_DJ wrote:A hybrid CT26 should hold better to the redline.A stock one won't.
Ryan S wrote:Gazza_DJ wrote:A hybrid CT26 should hold better to the redline.A stock one won't.
Yeah more curious as to why it won't though.Although I don't usually trust what american sites say mind you.
But on the other hand my friend says his held boost just fine.
androo007 wrote:Yeah as above.The ct26 just can't flow enough air.
That's why there's so much interest still in rev 3 conversions
(injectors ecu turbo etc).
Depends what you're after.Is JAAASHs gt28 still for sale
? Wicked quick spool and would do mid 300s
Gazza_DJ wrote:If his boost readings are correct, chances are the dude has a hybrid and doesn't realise.Not unreasonable for that to be the case
- externally it'll look the same and unless you know just how small a CT26 compressor is you probably wouldn't notice a larger wheel and the housing being machined.
There aren't many original CT26's left, and if you're spending
£££ on rebuilding it most will opt to spend a little bit more on a hybrid rebuild option.
