fitting a clutch!!!!!!
mase.1
Post by mase.1 »
hi all
i have a rev 1 turbo i need to change the clutch :cry: i was wondering if you have to drop the engine 1 side a little. Or after you have removed everything to get access (my mr2 cd for the computer helps!! :? ) can you do it all with just the front and rear engine mounts removed (not either side)
any help would be welcomed.
cheers shane
p.s i know there is a lot of other bits to remove but i just want to know if you have to drop the engine :? (cd does not help with that bit)
AM TUNING
Re: fitting a clutch!!!!!!
Post by AM TUNING »
no dont drop the engine , remove the rear subframe that makes it easer,
ps get help lifting it , its dam heavy
stevel
Post by stevel »
Welcome
this question was raised earlier
http://www.imoc.co.uk/forums/viewtopic.php?t=199
hth
mase.1
Post by mase.1 »
cheers andipandi
