Can you get the MK3 MR2 as a turbo?
Goto page 1, 2  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
adamshaw
1998 Toyota MR2 Mk2 Turbo Rev5
PostPosted: Mon Jan 02, 2006 6:25 pm    Post subject: Can you get the MK3 MR2 as a turbo? Reply with quote Reply with quote including images
As above - is the MK3 avaliable as a turbo?
if so what specs can be said of these babies?
Back to top
User is offline
aaronjb
2002 Toyota MR2 Mk3 Roadster
PostPosted: Mon Jan 02, 2006 6:27 pm    Post subject: Reply with quote Reply with quote including images
Only aftermarket turbo kits or engine conversions, not from the factory (though there is a TTE turbo kit, which is at least semi linked to Toyota)
Back to top
User is offline
steve b
Premium Member
1997 Mazda Eunos
PostPosted: Mon Jan 02, 2006 9:51 pm    Post subject: Reply with quote Reply with quote including images
The mk3's have some engine issues though, highly accelerated bore ware, engines going pop in quite high numbers with as little as 40,000 miles on them,.. and thats without turboing them [Sad]
Back to top
User is offline
Ekona
2004 BMW 6 Series
PostPosted: Mon Jan 02, 2006 10:28 pm    Post subject: Reply with quote Reply with quote including images
Not strictly true, and certainly not in high numbers.
Yes, pre-cat destruction has been known to take out a couple of engines, but as soon as you bolt a turbo on you remove the main manifold containing the pre-cats, therefore making the engine 100% more reliable.
Back to top
User is offline
Goldy
1993 Toyota MR2 Mk2 NA Rev3
PostPosted: Mon Jan 02, 2006 10:33 pm    Post subject: Reply with quote Reply with quote including images
BenF may be the person to speak to regarding this... He is currently running a mk3 turbo kit [Very Happy]
Back to top
User is offline
Ekona
2004 BMW 6 Series
PostPosted: Mon Jan 02, 2006 10:56 pm    Post subject: Reply with quote Reply with quote including images
He's not the only one [Wink]
FWIW, my Stage II Hass kit is putting out [email protected] on 5psi of boost, which is a similar power output to Ben's PE kit at 7psi. And that's quite enough power for me in the winter on cold roads, thankyouverymuch!
Back to top
User is offline
aaronjb
PostPosted: Mon Jan 02, 2006 11:02 pm    Post subject: Reply with quote Reply with quote including images
*mutters* [Laughing]
Not forgetting Sean, Mark, Tom and Ste (Hass, Hass, Hass and C2 Power) in the UK at present.. and another one or two PE kits, I believe (the guy with the black car, and wherever Perry's old kit went).
And Adam's 2ZZ-GE conversion [Twisted Evil]
No 2ZZ turbos in the UK yet, though..
I wonder if you could use a 2ZZ bottom end & 1ZZ top end (to lose the VVT-L gear, since you don't need the restrictive cam profile at low revs with a turbo) with aftermarket cams. [Think]
Back to top
User is offline
Peter Betts
Guest
PostPosted: Wed Jan 04, 2006 12:14 am    Post subject: Reply with quote Reply with quote including images
If that's Sean with the UK spec red 6 speed roadster he has our Turbo Conversion which is Charge Cooled and makes 235 bhp at the hubs @ 5 psi. We got 260 bhp at the hubs at 8psi but the clutch had words. These have proper equal length stainless manifolds and a hi flow CAT so pass all the MOT requirments. We also have a ECU with proper VVTi-L control and throttle by wire in a stand alone system come very soon.
We have also mapped two 2ZZ-GE Turbo Celica's so there must be at least two of them in the UK [Wink].
Nod.
Back to top
Slacey
Guest
PostPosted: Wed Jan 04, 2006 8:10 am    Post subject: Reply with quote Reply with quote including images
THOR-Racing wrote:
If that's Sean with the UK spec red 6 speed roadster he has our Turbo Conversion which is Charge Cooled.......
No; I was the black '02 spec car with the first Hass kit in the country - you guys mapped my car back in May last year. Impressive numbers from your kit though - I must stop by when I'm next over that way and take a look.
Back to top
Rowland
1999 Toyota MR2 Mk3 Roadster Turbo
PostPosted: Wed Jan 04, 2006 8:19 am    Post subject: Reply with quote Reply with quote including images
Mk3 Turbo here *waves*
Power Enterprise's Turbo BTW ~200 ish bhp with Greddy Emange and no intercooler. Yet [Shocked]
Back to top
User is offline
Premium Member
PostPosted: Wed Jan 04, 2006 12:52 pm    Post subject: Reply with quote Reply with quote including images
Moving to meber profiles....
just kidding [Laughing] [Laughing]
Back to top
User is offline
Rowland
PostPosted: Wed Jan 04, 2006 1:08 pm    Post subject: Reply with quote Reply with quote including images
www.dictionary.com
[Wink]
Back to top
User is offline
Premium Member
PostPosted: Wed Jan 04, 2006 1:11 pm    Post subject: Reply with quote Reply with quote including images
Rowland wrote:
www.dictionary.com
[Wink]
thanks for that, interesting site. Learnt a few new words. [Whistle] [Laughing]
Back to top
User is offline
Ekona
2004 BMW 6 Series
PostPosted: Wed Jan 04, 2006 6:27 pm    Post subject: Reply with quote Reply with quote including images
I'll let you know Sean, as I'm taking my car down there on Saturday to get it tuned and sorted.
Agreed on the power figures though, very impressive.
Back to top
User is offline
Slacey
Guest
PostPosted: Thu Jan 05, 2006 3:24 pm    Post subject: Reply with quote Reply with quote including images
Are you staying there for the day or doing a drop and run? If you are there for a while I might call in...
Back to top
Ekona
2004 BMW 6 Series
PostPosted: Thu Jan 05, 2006 3:34 pm    Post subject: Reply with quote Reply with quote including images
Unfortunately not: The car needs all the electrics sorting out properly (not the bodge job I've made of it! [Embarassed]), so I'll be leaving the car with them and hopefully picking it up next Saturday (if it's ready and I have time to get up there and back before the meal).
I can give you a buzz when I'm nearly there if you want? How long would it take you to get there?
Back to top
User is offline
Slacey
Guest
PostPosted: Thu Jan 05, 2006 5:20 pm    Post subject: Reply with quote Reply with quote including images
About 3/4 hour I reckon.
Back to top
Ekona
2004 BMW 6 Series
PostPosted: Thu Jan 05, 2006 5:44 pm    Post subject: Reply with quote Reply with quote including images
Okay bud, well I'll give you a shout when I'm about 45 mins away from there and see if you fancy popping along.
Back to top
User is offline
Slacey
Guest
PostPosted: Thu Jan 05, 2006 7:17 pm    Post subject: Reply with quote Reply with quote including images
What sort of time are you aiming to get there? PM me here or on ROC as we are drifting OT somewhat....
Back to top
BenF
Premium Member
2003 Toyota MR2 Mk3 Roadster Turbo
PostPosted: Thu Jan 05, 2006 9:13 pm    Post subject: Re: Can you get the MK3 MR2 as a turbo? Reply with quote Reply with quote including images
My ears are burning [Smile]
I spent a lot of time looking at Turbo'ing Roadsters last year.
Short answer - not offically directly from Toyota. There are various aftermarket kits that you can buy and fit that are now well proven on various different cars. Off the top of my head, there are :
- The TTE Turbo kit from Toyota. This one has has approval from Toyota and doesn't loose your warranty on the car. Its ~184bhp and they also add various additional bits of bracing to the car.
- The Hass Autoworks kit - Based on a GT-25 Turbo. Probably one of the first independent tuner kits - Hass are based in the USA. There's quite a long wait for kits to be delivered, but there are at least three here in the UK - Slacey and ekona both have this kit. This one produces good power figures from low boost due to the turbo relatively large size - 250bhp i seasily possible.
- The Power Enterprises kit. This is the one that Rowland and I both have - its based on a small IHI turbo and is designed to be bolt-on with minimal effort. The kit I've got has had some customisation and includes a chargecooler and fifth injector. Its running 220bhp @ 7psi - I think the kit as standard out of the box offers 190bhp.
There are other options too - C2 Power in Turkey has a GT-26 based kit available too, and Rogue Systems is working on a 3S-GTE conversion for a Roadster.
Bear in mind that the Roadster is around 975kgs, a 220bhp turbo conversion gives the same power/weight ratio as a 280bhp Tuned MK2 Turbo - but due to the lighter weight has improved handling and progressiveness on the limit. Having owned Mk1, Mk2 and Mk3 I have to say the Mk3 is great fun around the track - but I use my Mk1 as a trackday tool as I can afford to break/ bend / fix things on it [Smile]
To give you and idea: Roadster footage from Elvington:
http://www.imoc.co.uk/forums/viewtopic.php?t=17632
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
