1st question do Rev 2 Turbo's have one (oil light that is), 2nd question if so where on dashboard is it & 3rd question where is the sender on the engine cheers
The oil sender presure sender is on the same side of the distributa , but near the turbo just under the rocker cover oil pipe to the inlet pipe, its prety big and with one cable
you can just about see it on here right in the middle at the bottom between the strut brace and the big hose comming out of rocker cover
Thanks Merlin now I know where to look I can start to investigate, you can't tell me where on the dash it should be could you, it might obnly be a bulb.
