rogue fan kit thread bore information?
demonslayer
Post by demonslayer »
Hi Everyone,
I am trying to find out the threads on the mid-section of the good old rogue fan shroud.
Somehow it must be something m5 -ish. The others surrounding sure are m6.
I am not able to mount my temp sensor at the moment/After reinstalling this kit again.
I know I had the temp sensor mounted once, i see the marks, but I have no clue which bolts I used.
Maybe one of You can check this for me on his/her lid/shroud.
thank you,
Dan
[/img]
demonslayer
Re: rogue fan kit thread bore information?
Hello, can someone help please?
wilkie senior
Post by wilkie senior »
I dont think that are that many Rogue shrouds around to try but surely they would be using the same as the std bolts to fasten the sensor on?
I would suggest you would have more luck contacting Rougue directly?
regards Brian
wilkie senior
std bolts would be as i recall m6x1.0 metric bolts
I will have a check round for you
demonslayer
Thank you,
I contacted Rogue, and they tried to help me. In any case they dont have such shrouds to check for me, but are certain they used metric tapings.
So I removed the shroud and checked its rear side/ the threads, and realized that powder coat drained into the last section of the threads.
So its M5x0.8 metric for these 2 holes on the sensor.
All other main bolts are M6x1 metric .
mystery solved :)
Now I have to think about how and where to connect the dual Spals that the temp sensor controls them. As they drain quiet some amps they should go to a Batterie + somewhere.
