I read somewhere that the ecu can learn up to 4 different key fobs
My rev4 spare key appears to be from a different car but has the same fob as the working key
Can the following proceedure work with mr2?
1
Open the driver's side door; make sure all the other doors are closed.
2
Put your key into the ignition
(without turning) twice within five seconds.
Close the driver's side door, and then open the driver's side door.
3
Close the driver's side door, and then open it again.
Put your key in the ignition and quickly pull it out.
Close the driver's side door again, and then open it.
4
Close the driver's side door again, and then open it again.
Put your key in the ignition, and then close the driver's side door.
Turn the key to the
"On" notch, without cranking, and then turn it off.
Remove the key from the ignition.
5
Listen for the door locks to cycle; this confirms the process was successful.
If the door locks do not cycle, repeat the entire procedure.
6
Hold the
"Unlock" and
"Lock" button on the key fob for two seconds, and then press and hold the
"Lock" button for three seconds.
Listen for the door to lock, and then unlock.
How to Program Toyota Key Fobs
| eHow.co.uk Here are the instructions for the 2003 Toyota Corolla Model.
1.
Start with the key out of the ignition.
Open the driver door
(all other doors are closed).
Driver door is unlocked
(other doors dont matter).
2.
Perform these steps within 5 seconds
a.
Insert the key into the ignition
(dont turn it) Pull key out
b.
3.
Perform these steps within 40 seconds
a.
Close, then open the drivers door.
b.
c.
(dont turn it) and pull it out.
4.
a.
b.
c.
Insert the key into the ignition and leave in the ignition.
d.
Close the drivers door
Turn the ignition to ON
(as far as you can go without cranking the engine), then back to off
e.
5.
Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6.
a.
Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
b.
Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should lock then unlock once indicating successful programming.
If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
7.
Open drivers door
I can it to cycle the Mr2 locks but it seems to refuse to learn the other fob.
Any ideas?
