Need some help, my aftermarket alarm on my 2 has a remote start feature at the moment I've just wired it to unlock and lock car etc but would like to get the remote start up and running,
I've worked out 99% of the wiring but my alarm has a wire labled
They both seem to read 12v with ignition on and the same when engine started, I would of thought a tach line would read no volts when ignition on but 12v etc when running?, if the alarm sees a 12v at ignition on from the tach then surely it would assume the engines already started and not even fire the starter?
