[Mk2] [Turbo] Presume this is a capacitor gone? - would it cause these issues
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
killerferret666
PostPosted: Sun Apr 01, 2018 5:14 pm    Post subject: [Mk2] [Turbo] Presume this is a capacitor gone? - would it cause these issues Reply with quote Reply with quote including images
As I say Presume this is the Capacitor gone, I think Ive caught it early;
this is a rev3 if there is any difference between them.
symptoms;
* Noticed two small flashes of Engine ECU light
* High idle - Prior to this hunting idle.
* running rich (smells rich)
* Power seems down then back to normal
* Engine light should come on at 50mph+ for me as ABS ecu disconnected - but now doesnt.
I cant see any of the others gone.
To get this repaired anyone got recommendations of who to send it to and the capacitors.
Back to top
User is offline
markstevieandmads
PostPosted: Sun Apr 01, 2018 7:59 pm    Post subject: Reply with quote Reply with quote including images
looks like you caught it early.
Doesnt look like its caught any tracks from your pics though its hard to say. Your get away with cutting the legs off and soldering a new one on of the same value.
Back to top
User is offline
Pauln
Premium Member
PostPosted: Sun Apr 01, 2018 10:12 pm    Post subject: Reply with quote Reply with quote including images
While your at it I'd be tempted to replace the other 10mf capacitor on the smaller board as a precautionary measure even though it may not look as though it's leaking at present, as these two caps seem to be the ones most prone to leaking.
If you decide to desolder the old caps, rather than simply clipping off the old caps before soldering new caps onto the legs as has been suggested, from memory I believe the caps need to be soldered on both sides of the double sided board. Just remember to remove any gunk from the old caps you find on the circuit board as it will eat into the tracks.
A quick coat of PCB lacquer afterwards is also a good plan to help protect the boards.
Paul
Back to top
User is offline
killerferret666
PostPosted: Sun Apr 01, 2018 10:20 pm    Post subject: Reply with quote Reply with quote including images
thanks both, I didn't even think about cutting on the legs and just cleaning the board, A much better idea for my amateur soldering skills.
I have soldered before, but just not on PCB board
Back to top
User is offline
ElvisRockVinyl
1993 Toyota MR2 Mk2 NA Rev2
PostPosted: Wed Aug 14, 2019 11:14 pm    Post subject: Reply with quote Reply with quote including images
I recapped mine a few years ago, you can test them in circuit with an ESR meter, I had 2 gone both reading very high ESR replaced them and engine ran a lot smoother, my 2 symptoms where hot start issues and high idle every so often even after a idle valve clean.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
