Possible head gasket issue
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC
Author Message
Tiger Tim
PostPosted: Thu Aug 08, 2019 8:10 am    Post subject: Possible head gasket issue Reply with quote Reply with quote including images
Wonder have I a head gasket issue. Here’s the story. MR2 MK1A is only used for car shows & vintage runs. When I return from a run the engine has pushed out about 2 inches of coolant into the expansion bottle. But when it cools down it only takes back about half an inch of coolant to the engine. Normally I just syphon out the coolant from the bottle the following day & pour back into the filler neck & repeat after every run. Compression is perfect in each cylinder & radiator, thermostat, filler cap & expansion cap have been replaced. Coolant has been bled correctly & idle is perfect & no sound of air in the pipes. I got my mechanic to detect any exhaust gasses in the coolant using his kit & nothing detected. Pressure must be getting into the cooling system. Not sure why the coolant isn’t being pulled back into the engine. New cap is .9bar. Did a 60 mile run last Sat in quite hot weather & extra coolant was pushed out to expansion bottle & a little taken back. I found this time that I couldn’t return the same amount of coolant to the filler neck so I’m guessing that there must now be some air in the system. I have a mark on the expansion bottle just above half way so I know what my starting point is. Anyone got any ideas?. Might be a head gasket job over the winter.
Thanks,
Tim
Back to top
User is offline
[email protected]
IMOC Affiliated Company
PostPosted: Fri Aug 09, 2019 9:11 am    Post subject: Reply with quote Reply with quote including images
Sniff tests aren't conclusive on 4a-ge engines, the HG breach can be so fine (usually around number 4 cylinder to water jacket) that it will only blowby exhaust gas under load.
The test i use is to carry out a leakdown test (just apply 50psi to each cylinder at TDC) with the coolant filler cap off, if there are bubbles then it 100% has a HG issue, if there are no bubbles then it passes.
Over the last 20 years this test and only this test has worked for me, hope that helps.
_________________
Back to top
User is offline
Tiger Tim
PostPosted: Sat Aug 10, 2019 4:45 pm    Post subject: Reply with quote Reply with quote including images
Thanks Paul, I read about your hollowed out spark plug on another thread. Was hoping it wasnt the HG but probably is. Will test.
Thanks,
T.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC All times are GMT
Page 1 of 1
Jump to:
