Key linked to ECU 1998 UK Rev 5 N/A
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
wilkie senior
1992 Toyota MR2 Mk2 NA Rev1
PostPosted: Thu Jul 11, 2019 11:10 am    Post subject: Key linked to ECU 1998 UK Rev 5 N/A Reply with quote Reply with quote including images
Hi
As above ive never heard of this
Im going through suggested solutions to sort this erratic idle & over fuelling
Talking to someone today about the issue (buying a part) they asked about the key have i linked it to the ECU, I even tried a ECU from a rev 5 breaker to eliminate th eoriginal.
Now Ive never heard of this before (hat means nothing though) its runs as the previous ECU did
now this comment thrown into the pit, im getting pretty hacked of, its on the edge (despite a fortune on bodywork) ditching the thing!!!
I really need to get to someone that can bottom this, but i dont know of anyone near me (skipton / Colne) as the MOT has run out, vicious circle, cant cure this it wont pass mot on emissions, so cant drive it to someone etc etc
(a vert dejected) Brian
_________________
Hail Cosmos Eagle 1998 -
RIP White Eagle 1991 - 2016
Back to top
User is offline
SonicSW20
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Thu Jul 11, 2019 11:53 am    Post subject: Reply with quote Reply with quote including images
The key is NOT linked to the engine ECU. I have swapped out UK market Rev4 and Rev5 ECU's (both use the same security system pretty much) - you can swap them for another of the same part number with no issues. As far as I am aware, its the TVSS box that handles all the key related stuff.
Are there any codes present, and what have you done so far to try to fix this?
Back to top
User is offline
wilkie senior
PostPosted: Thu Jul 11, 2019 11:57 am    Post subject: Reply with quote Reply with quote including images
Hi there
Thanks for that I thought i was going crazy!!
to my shame no i have not....but tonight we will and take it from there.
Be ready for a long thread ! I hope not!
Regards Brian
Back to top
User is offline
SonicSW20
Premium Member
PostPosted: Thu Jul 11, 2019 12:00 pm    Post subject: Reply with quote Reply with quote including images
wilkie senior wrote:
Hi there
Regards Brian
Just got to work through methodically, more often than not these things end up being something actually quite simple, its just a matter of going through and testing. Could be as simple as a perished / split vacuum hose somewhere!
Back to top
User is offline
wilkie senior
PostPosted: Thu Jul 11, 2019 12:09 pm    Post subject: Reply with quote Reply with quote including images
Ive been going at it all wrong i think I replaced so many things, replaced some vac hoses but there are some i cannot fathom how you get to the other end, they descend into the abyss of the engine bay!!!
I will report back with the results
Thanks for taking the time to reply most appreciated
regards Brian
Back to top
User is offline
Ryan S
PostPosted: Thu Jul 11, 2019 6:53 pm    Post subject: Reply with quote Reply with quote including images
get the car on ramps Bri, It's much easier to work out where stuff goes when you can see from the top and bottom. Looking into the top yields very little in my experience.
_________________
www.straitupstudios.co.uk
Back to top
User is offline
wilkie senior
PostPosted: Fri Jul 12, 2019 8:01 am    Post subject: Reply with quote Reply with quote including images
With my lack of time & facilities I may be taking it somewhere
Did the fault chaeck last night got 4 flashes then 1,
acording to info Fault 41 TPS Position Sensor
Open or short circuit in throttle signal (VTA)
* Throttle position sensor circuit
*Throttle Position Sensor
* ECU
I already changed the ECU with no change so taking a relative guess that it wasn't ECU ?
We tried setting up the TPS according to BGB, it was hard to get a reasonable result that appeared stable,
Now IDIOT here!!! was messing with the throttle stop screw when it all started, ( I know now you don't mess with this)....or do you?
Now to start the set up process, how to a get the stop to a starting position?
do i adjust the stop so it just touch's? then i can start again
Also on another thread there reference to the switching of "IDL Switch" forgive my ignorance but where what when so to speak
Back to top
User is offline
SonicSW20
Premium Member
PostPosted: Fri Jul 12, 2019 8:10 am    Post subject: Reply with quote Reply with quote including images
IDL is one of the pins on the TPS.
I've never touched the throttle stop screw personally, you should never need to, it's set from the factory and thats it. Is there anything in the workshop manual for it?
If you were able to calibrate the TPS you would have checked that the IDL output on the TPS was working correctly. So, that suggests your TPS is OK. I'd still try another one to be sure, but if it calibrated correctly I think you probably have a wiring issue.
Back to top
User is offline
wilkie senior
PostPosted: Fri Jul 12, 2019 8:13 am    Post subject: Reply with quote Reply with quote including images
Hi
Yep big homer Simpsons moment re the throttle stop, kicking myself
I will have a look in the BGB to see if theres anything.
i think physical check of the wiring is in order old cars various garages of varying quality of work etc
Thanks chaps all appreciated
regards Brian
Back to top
User is offline
Ryan S
PostPosted: Fri Jul 12, 2019 5:26 pm    Post subject: Reply with quote Reply with quote including images
is the TPS the same on NA and turbo?
Back to top
User is offline
SonicSW20
Premium Member
PostPosted: Fri Jul 12, 2019 6:03 pm    Post subject: Reply with quote Reply with quote including images
Yeah, super common part. Same on loads of Toyotas from the era. Should not be an issue to find one!
http://japan-parts.eu/?parttt=&part=89452-22090&regi=&cars=ok
Back to top
User is offline
abovetherim
Premium Member
1991 Toyota MR2 Mk2 NA Rev1
PostPosted: Fri Jul 12, 2019 10:18 pm    Post subject: Reply with quote Reply with quote including images
Here is something to check that won't cost you anything...
Both the TPS and the MAP sensor (thingy near the diag box on the firewall with a vac hose running to the underside) use E2 connection to the ECU. I believe there is a splice in the loom somehere under the inlet manifold.
You could attach a straight crimp connector to some wire then slot this on the terminal (Brown wire IIRC) for the tps plug and run the wire to the boot. Then using a meter check the continuity between E2 pin in the grey plug at the ecu (you can open up the ecu to check which pin as they are labelled but i believe it is on the 16 pin plug) and the tps.
Also do this for the MAP sensor as if this is getting intermittant or broken E2 connection then the engine will overfuel.
Once you have the idle screww set reset the TPS adjustment as per the bgb. and then check with 0.5mm feeler and 0.7mm feeler. 0.5mm should show between IDL and E2 (botton 2 terminals in the connector) 2.3KOhms or less
0.7mm should show infinity.
To set initially it is easier with an old fshioned needle meter. Using 0.6mm feeler in the throttle stop loosen tps screws and move the tps until the guage flicks from infinity to continutity...ish. then check with 0.5 and 0.7
Hope this helps
Back to top
User is offline
abovetherim
Premium Member
PostPosted: Fri Jul 12, 2019 10:22 pm    Post subject: Reply with quote Reply with quote including images
Also worth wipping of the throttle body and the iac and giving them a clean. they can get gunked up.
After cleaning the iac with carb cleaner and checking the gate turns super free dry it out and spray a little WD40 at the bearings (either end of the gate as it were).
Back to top
User is offline
wilkie senior
PostPosted: Sat Jul 13, 2019 7:45 pm    Post subject: Reply with quote Reply with quote including images
Hi I did the throttle body ac while back
But!!!!!! But!!!! Think we found the culprit today
Will post details next time, but seems better
Brian
Back to top
User is offline
wilkie senior
PostPosted: Tue Jul 16, 2019 9:11 am    Post subject: Reply with quote Reply with quote including images
well sorted it
the fault, well err umm it was well, err
the breather (blue) the little white pipe going into it, got pushed too far, touching the top of the breather housing!!
so pulling it off in a real hissy fit causing it to run, well di i feel a complete as Del boy would say "Rodney, you plonker! "
Needless to say the little b*****r will be made fixed in the appropiate position!!!
oh well just fine tune the TPS setting etc, well at least shes had a lot of good quality parts fitted, plus I have a alot of good quality parts for sale!! ha ah
Regards Brian
"Winner of Plonker of the month award July 2019"
Back to top
User is offline
SonicSW20
Premium Member
PostPosted: Tue Jul 16, 2019 9:15 am    Post subject: Reply with quote Reply with quote including images
Is that a breather, or is that the air supply for the IACV?
Back to top
User is offline
wilkie senior
PostPosted: Tue Jul 16, 2019 9:23 am    Post subject: Reply with quote Reply with quote including images
Hi
Its a breather was put there by a previous owner,( i have renewed the filter & check for being clean, on a regular basis)
I have though of plumbing it back in as std? in the induction pipe thoughts?
Brian
Back to top
User is offline
SonicSW20
Premium Member
PostPosted: Tue Jul 16, 2019 9:36 am    Post subject: Reply with quote Reply with quote including images
If its the one that goes to the intake pipe, thats the air feed for the IACV. Certainly explains the poor idle if it was blocked.
Back to top
User is offline
wilkie senior
PostPosted: Tue Jul 16, 2019 9:57 am    Post subject: Reply with quote Reply with quote including images
Yeah indeed
I feel such a total "Helmet" ha ha
Anyway at least she can get her ready for a MOT, and crack on with the legal action against the previous body shop for their bodge work that has been corrected now
The Rebirth of the Cosmos Eagle continues [Smile]
Back to top
User is offline
wilkie senior
PostPosted: Tue Jul 16, 2019 12:52 pm    Post subject: Reply with quote Reply with quote including images
Hope this helps
Cheers for that Ill bear it in mind, i did have to read it 3 times ha ha, life was so much esier with my cross flows, twin cams & A series engines, even doing a 1360 with split webers seemed easy compared to these things ha ha
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
