If you disconnect the plug going into the temperature sensor on the engine lid the stock fan will run continuously.
You can then simply swap fans, provided your new fan doesn't draw substantially more current than the stock one, which is unlikely.
The wiring to the stock fan should be Blue with Red stripe
+ 12v and black with White stripe
-12v), just connect those to the correct wires on your new fan.
Paul
