My mirrors arnt working at all.
![Image](https://i.imgur.com/QLlf9Fb.jpg)
As you can see there's some wires not connected to anything.
Ross.
Pauln wrote:Well that's pretty good progress.Well worth checking the wiring again, the following wiring diagram should help identify the wires that relate to the drivers mirror folding function.
Don't forget these colours relate to the stock door harness not the cables that connects to the harness in the door, which isn't stock.
http://www.mr2.org.uk/images/JDM_Folding_Mirrors.jpg
I found this in a posting on the MR2OC forum when I was upgrading to folding mirrors.Unfortunately it's in Japanese but I've added the correct colour codes which were translated in another post.
If the connections are OK, it might be worth folding the passenger mirror via the switch, then manually folding the drivers mirror.
Then click the switch to open them.
If the drivers mirror unfolds via the switch it's likely to be a faulty limit switch in the mirror housing.
I guess at a push it could be a faulty relay.But I think that's far less likely as the passenger side is working.
Here's a link to the OC thread which you may also find helpful.
MR2OC Post
Good luck.
Paul
