Just bought a Shed! * Pictures added!*
Goto page Previous  1, 2
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
Rory
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Thu Nov 22, 2018 12:56 pm    Post subject: Reply with quote Reply with quote including images
My 96 doesn’t have abs.
Back to top
User is offline
chooch
1989 Toyota MR2
PostPosted: Thu Nov 22, 2018 1:19 pm    Post subject: Reply with quote Reply with quote including images
Thanks, that's good to know!
Back to top
User is offline
PostPosted: Thu Nov 22, 2018 2:11 pm    Post subject: Reply with quote Reply with quote including images
chooch wrote:
Should my car have ABS or not? It's a 96 UK car as above, there is no light on the dash and the wheels lock up when you hit the brakes! I just thought a car of this age would have it...
You'll be able to tell if it has ABS by looking under the bonnet. Should be ABS unit on left (as you're looking at the car from the front).
Back to top
User is offline
pbmr2
PostPosted: Thu Nov 22, 2018 7:10 pm    Post subject: Reply with quote Reply with quote including images
could be a late rev3. all the lights have had work so hard to say if it's a 3 or a 4. got a pic of the engine? that'll tell us. look for the egr valve.
Both my rev4 cars have abs, but one of them has cloth seats. They both had airbag steering wheels too.
Unless you want to get welding and want a big project, then it's not worth saving sadly
Back to top
User is offline
chooch
1989 Toyota MR2
PostPosted: Fri Nov 23, 2018 12:58 pm    Post subject: Reply with quote Reply with quote including images
Hi,
Does this help?
I have an airbag on the steering wheel. The car has leather trim on the doors, which makes me think that the seat had seen better days and got swapped out...
btw. this is my old MR2 from around 2005...
Back to top
User is offline
androo007
PostPosted: Fri Nov 23, 2018 6:03 pm    Post subject: Reply with quote Reply with quote including images
That MOT history is great!
Love the comment about it being a sixteen year old car blah blah...
Obviously a friendly tester as it always failed emissions... then passed... then failed... then passed.... haha
Back to top
User is offline
pbmr2
PostPosted: Sat Nov 24, 2018 9:03 pm    Post subject: Reply with quote Reply with quote including images
That's a rev4 engine, can see the EGR setup.
Back to top
User is offline
chooch
1989 Toyota MR2
PostPosted: Mon Nov 26, 2018 12:24 pm    Post subject: Reply with quote Reply with quote including images
That's great thanks! Maybe I should invest in an EGR blanking plate, to free up some ponies and eliminate any potential issues...
I got a shot under the bonnet, am I right thinking that this is an ABS pump?
cheers,
Ewan
Back to top
User is offline
MartinF
PostPosted: Mon Nov 26, 2018 12:52 pm    Post subject: Reply with quote Reply with quote including images
Yes, that is an ABS pump
Back to top
User is offline
chooch
1989 Toyota MR2
PostPosted: Mon Dec 03, 2018 1:09 pm    Post subject: Reply with quote Reply with quote including images
So after driving the car in the rain and parking it out in the rain, it wouldn't start last week. Thankfully I managed to get it started at weekend and have it inside now.
upon inspection I found the boot flooded.
I can only guess that it has been coming from the wheel arch where there is a much bigger gaping hole than expected!
Could this have played havoc with the ECU? it seemed dry...
Back to top
User is offline
PostPosted: Mon Dec 03, 2018 1:12 pm    Post subject: Reply with quote Reply with quote including images
Possibly, due to moisture getting inside it. That's a big hole!! [Surprised]
Back to top
User is offline
Draven
PostPosted: Wed Dec 12, 2018 10:18 am    Post subject: Reply with quote Reply with quote including images
That is a lot of fails. it failed pretty much every year.
Good luck sorting it.
Back to top
User is offline
pbmr2
PostPosted: Wed Dec 12, 2018 12:12 pm    Post subject: Reply with quote Reply with quote including images
Normally the coil gets cracks in it and then water finds it's way in. would be my first guess.
Back to top
User is offline
chooch
1989 Toyota MR2
PostPosted: Thu Jan 03, 2019 11:47 pm    Post subject: Reply with quote Reply with quote including images
No plans to sort it, current plan is to drive until MOT expires, then break for spares, hopefully gather enough funds to cover expense of car and maybe buy another...
Thanks, coil was fine, think it was condensation upsetting the ECU or something else.
Back to top
User is offline
chooch
1989 Toyota MR2
PostPosted: Mon Feb 11, 2019 11:44 pm    Post subject: Reply with quote Reply with quote including images
Well I took it out in the snow and managed to survive! It developed a fault with the steering (possibly due to the cold) and wanted to go sideways on the straights! So I took the car to my local garage and the steering rack is fubar! It's as if the rack and pinion are skipping... However surprisingly they said the car is fairly solid and would only take a couple hours welding to fix the wheel wells [Shocked]
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 2 of 2
Jump to:
