Head blew again between 3&4.
1) Does anyone know if the ca 3 mm diameter coolant holes in the block that point in between the cylinders are supposed to be blind or should there be a flow through them?
2) What is the size of the crankshaft/oil pump oil seal, presumably this can be prised out without removing the oil pump?
88 mk1b
Many Thanks
Jim
