HI all
been having problems with the second fuel pump melting fuses so just replaced it with a new bosch 044,
now the car starts and drives fine but i just noticed the hand controller of my apexi fc stays on with keys out of the ignition draining battery
also noticed that when i used to turn the key the pumps used to prime before starting the car now they prime after i switch engine off ?
i guessing some melted wires somewhere but car runs fine, any ideas where to look first
many thanks
Tony
[Mk2] [Turbo] ecu powered with ignition off
If you see an MR2 with a raised engine cover, the bottom line is it's probably faster than your car.
Re: [Mk2] [Turbo] ecu powered with ignition off
found it melted ecu wire getting power from another wire 2 min fix
Eek, not good! Hoepfully that's the only one
Well it works properly now so fingers crossed, it was a black and yellow wire fused to a white and red lol my own fault to
