Is this weldable ?
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK3 2000-2007
Author Message
Truzo
PostPosted: Wed Aug 08, 2018 5:58 pm    Post subject: Is this weldable ? Reply with quote Reply with quote including images
Hi, I would just like some advice on my subframe.
Is this mess weldable or is it a new subframe job ?
As you can see the hole is directly next to one of the rear control arms. (Hidden behind it)
Cheers, Truzo.
Back to top
User is offline
androo007
Premium Member
PostPosted: Thu Aug 09, 2018 12:34 pm    Post subject: Reply with quote Reply with quote including images
Given you can find a good replacement subframe for around £50, i'd say that's had it's day!
Back to top
User is offline
SonicSW20
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Thu Aug 09, 2018 1:05 pm    Post subject: Reply with quote Reply with quote including images
I think W30 subframes go for a bit more than that but still, I'd be replacing and treating the replacement so it won't rust like that one has.
Back to top
User is offline
JD
Premium Member
PostPosted: Thu Aug 09, 2018 5:24 pm    Post subject: Reply with quote Reply with quote including images
Like Gazza says, just replace with a good one, blasted and powder coated/sprayed, then spaff some dynax s-50 (or any decent cavity wax) inside to keep it from rotting from the inside out.
Back to top
User is offline
Truzo
PostPosted: Thu Aug 09, 2018 8:20 pm    Post subject: Reply with quote Reply with quote including images
Thank you all for the input it's much appreciated.
I had a look on ebay for a replacement but the one I found was for a pre facelift. Mine is a 2003 facelift 6 speed, Am I right in thinking there is two types of subframe ?
Cheers Truzo.
Back to top
User is offline
toxo
PostPosted: Fri Aug 10, 2018 10:08 am    Post subject: Reply with quote Reply with quote including images
Pre and post facelift are different subframes. The main difference is that the post facelift has more underbody bracing, and as a result there are mounts for the additional braces on the later subframe. You can run a pre facelift subframe on a post facelift car, you just lose the extra braces.
When mine rotted through I ran a pre facelift frame I picked up for cheap for a while until I found a decent post facelift one. I ended up buying a brand new one from Camskill at half the price it would've been from Toyota (they are about £280 new from Mr T if I remember right). Unfortunately for you, Camskill don't do OEM parts anymore.
Post facelift subframe part number is 51206-17040.
_________________
Back to top
User is offline
Truzo
PostPosted: Tue Aug 14, 2018 12:30 am    Post subject: Reply with quote Reply with quote including images
OK so I took the car down to my local import specialist in Derby,(Brian at Power House) he also advised me that it would be best to just replace. I can't find a face lift one anywhere so I'm gonna have to buy a new one from toyota. I can only assume they put extra bracing on for a good reason. I will also give it a few coats.of hammer right or similar and fill it full of waxoil. I did spot a post while looking for subframes of a chap who went round the hole thing with seam sealer but maybe that's a bit much.
Cheers Truzo
Back to top
User is offline
toxo
PostPosted: Tue Aug 14, 2018 6:22 am    Post subject: Reply with quote Reply with quote including images
Yeah, it sucks but it's the best course of action really. I tried pursuing Toyota's 10yr anti corrosion warranty at the time but they weren't having it. The only saving grace is that the subframe is very easy to replace! It's light and there's not much holding it on and only 1 exhaust pipe in the way. It can easily be done on the drive, but you will want a wheel alignment afterwards.
Back to top
User is offline
Truzo
PostPosted: Wed Aug 15, 2018 11:51 am    Post subject: Reply with quote Reply with quote including images
OK, So I have just picked up a new subframe from a Toyota “stealership” and new bolts just in case.
After looking the new part over I can 100% see why they rust so bad.
The weld looks like Stevie Wonder had a crack at it, lots of pin holes undercutting and a mess.
They didn't clean the welds before painting it so there is a lot of paint missing on the welds. And the paint itself is super thin.
I am considering going round it with seam sealer before re painting it, Do you think this would be a good idea ?
Cheers Truzo.
Back to top
User is offline
toxo
PostPosted: Wed Aug 15, 2018 12:03 pm    Post subject: Reply with quote Reply with quote including images
I think anything you can do can only protect it more. You could even get it powdercoated!
If you don't mind saying, how much have they increased in price?
Back to top
User is offline
Truzo
PostPosted: Wed Aug 15, 2018 12:17 pm    Post subject: Reply with quote Reply with quote including images
It was just shy of £348 including vat so not a cheap part considering it needs painting and possibly sealing.
Quick Edit. This post should be in the off topic thread under "Worst pain you've experienced"
Back to top
User is offline
toxo
PostPosted: Wed Aug 15, 2018 1:09 pm    Post subject: Reply with quote Reply with quote including images
*sharp intake of breath*
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK3 2000-2007 All times are GMT
Page 1 of 1
Jump to:
