[Mk2] [Turbo] Plastic welding broken fog mounts?
b4ss
Post by b4ss »
Hi,
Has anyone had any success in plastic welding broken fog light mounts together again?
I am thinking about trying it, as mine are steering fogs, but need to figure out what type of plastic etc is used and if it is worth doing.
thought maybe someone else has tried and has some useful info :)
Thanks,
Tony
alanmr2turbo
Re: [Mk2] [Turbo] Plastic welding broken fog mounts?
Post by alanmr2turbo »
I have done loads of these. Soldering iron and black zip ties.
b4ss
Post by b4ss »
alanmr2turbo wrote:I have done loads of these. Soldering iron and black zip ties.
That will do nicely - thanks a mil :)
Tony
platmatt8
Post by platmatt8 »
I've looked at plastic welding recently to fix my splitter, it seems heat and a polyethylene does the job easily. Hard part is trying to jack the front of the car up :neutral:
pbmr2
Post by pbmr2 »
platmatt8 wrote:I've looked at plastic welding recently to fix my splitter, it seems heat and a polyethylene does the job easily. Hard part is trying to jack the front of the car up :neutral:
park the front on some planks of wood to give a little room for the jack?
adam3442
Post by adam3442 »
I used Q-Bond to fix mine, seemed to work ok.. Then drilled out the stock captive nuts and put rivnuts in...
wilkie senior
Post by wilkie senior »
Perhaps not full of finesse
But i did this on my White Rev1 stayed put & still there when i sold them on
