What it says really, what success have people had?
After changing lambda and checking over water temp sensor and both now ok and good, i think im left with either
1) vacuum leak - possible as idling about 1000rpm now
2) ECU repair just didnt repair it
Id prefer option 1 but need to find a way to test it.
[Mk2] [Turbo] DIY methods of testing for Vacuum leak
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
Re: [Mk2] [Turbo] DIY methods of testing for Vacuum leak
Blow smoke from a fag into the system.
Worked for me to see a loose nut between turbo/manifold.
- IMOC Moderator
simple but cracking idea!!
i will use that
get someone who vaps those things seem to creat their own fog banks!!
ha ha
i will use that
ha ha
Used fag smoke for side of the road testing. Tend to use a cheap smoke machine now, just waft it around the engine bay and you can see the smoke get sucked into the leak.
Cost about £25 on ebay years ago
