[Mk2 [NA] Idle issue
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical
Author Message
wilkie senior
1992 Toyota MR2 Mk2 NA Rev1
PostPosted: Tue May 22, 2018 4:01 pm    Post subject: [Mk2 [NA] Idle issue Reply with quote Reply with quote including images
Hi IMOC'rs i have an issue, the car runs fine when started, idle is perfect for ages at junctions etc for quite while then, im at a junction then the revs go low down & can stop. But give it a blip or a little loud pedal, idles ok again for a while.
I suspect a vac leak, or is it likely to be the Idle Comtrol Valve? dirty or the electrical activator?, thoughts peeps ta muchly
regards Brian
_________________
Hail Cosmos Eagle 1998 -
RIP White Eagle 1991 - 2016
Back to top
User is offline
mrhappy62
PostPosted: Tue May 22, 2018 6:45 pm    Post subject: Reply with quote Reply with quote including images
dirty idle speed control valve imho
Back to top
User is offline
wilkie senior
PostPosted: Tue May 22, 2018 7:18 pm    Post subject: Reply with quote Reply with quote including images
Hi cheers seems to be favourite after googling around
Brian
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical All times are GMT
Page 1 of 1
Jump to:
