so i have started to do some bits to the v6 mr2 and the 1 real mod was the seat although they are in fantastic condition for
a 23 yr old car i didnt like the seat as it had obviuosly over time and bodies
, sagged so i looked at leather
( not good enough condition and prob with the same issue or change them for say gt86
etc
, but i love the seats lumbar
, bolster adjust etc so i decided to remove the drivers seat and see what i could do.
tools
14 mm socket
flat and philipps driver
small pry bar
long nose and standard mole grips
stanley blade or sciccors
and a seat foam from a garden chair
(dont tell the wife
![Image](https://i.imgur.com/Pf6ETsG.jpg)
first remove seat
.14 mm socket
, dont forget to remove the boot fuel release unit.
1 flat head under the
boot release pulls and a philips that holds it to the floor
(seat
) mount
then place on a work bench
starting at the front there are 3 brass rings that need to be prized open and kept for replacing
![Image](https://i.imgur.com/b28UknC.jpg)
then with the mole grips flatten out the 2 corners of the
large metal pad held by the 4 x spings to ease the springs off on 1 side so you can put the foam under
![Image](https://i.imgur.com/FJFMzT8.jpg)
then cut the foam pad to size and slide under the remaining metal pad with the seat pad warning connector on
, all the way to the front of the seat
then with any remaing
off cuts
( i had 2 long lenths.
i put these under the spring pad
(at the rear
) to keep the rear of the sqaub up as well
![Image](https://i.imgur.com/7WollBW.jpg)
then
reverse of removal
dont foget when you bent the 3 brass rings to secure the front of the squab to the seat frame
, you have replaced
, to turn them around
() into the foam section.
.as if a later date you loose a pound and rumage under your seat you wont cut yourself couse these are bloody sharp!!!!
seat is now prob firmer than it was when new and it cost pennies
![Image](https://i.imgur.com/jTh675u.jpg)
[/img]
https://i.imgur.com/oEILwp9.jpg[img]
[/img]
![Image](https://i.imgur.com/oEILwp9.jpg)
