Hi does anyone know where I can get a new replacement belt for my SC with aircon, obviously there's Toyota, but with it being an import,
I wasn't sure of the availability, that and its a 15 mile drive to my nearest absoulty useless dealership.
I had a quick Google but only found belts for the n/a or the SC with NO aircon.
Chris
Alternator belt for a mk1 SC
Re: Alternator belt for a mk1 SC
I'll have a look at mine to see if the size markings are still legible.
Try importcarparts.co.uk
Used them a couple of times always have the obscure parts.
Hope that helps
Brad
Hope that helps
Brad
- Lauren
- IMOC Committee
You'll be able to get it from Toyota. Or try Toyota RRG Macclesfield. 01625 869 900. Ask for Paul, he'll be able to post it up to you.
2020 GR Yaris - Circuit Pack
Thanks for the replies, I've got one coming from Fensport.
Surely you only need to know the length & number of ribs, a belt is a belt is a belt?
The old belt was damaged, so was unreadable and I was unable to take a measurement for the same reasons.
I do have a modicum of intelligence.
For thanks for your 'input'
Take it as sarcasm if you wish it wasn't intended so, but if it's still in one piece than all you had to do was fold it in half, measure top to bottom & double it, or get a piece of string & put it around the outside & again measure it. But as you have a modicum of intelligence you would already know that so I'll let you waste your money at Fensport when you could have gone to Eurocarparts.oukie wrote:The old belt was damaged, so was unreadable and I was unable to take a measurement for the same reasons.
Would be great to post up the size once you have received (and checked it fits) so it can be searched for by anyone in the future.
Cheers,
Jon
Cheers,
Jon
phaeton wrote:Take it as sarcasm if you wish it wasn't intended so, but if it's still in one piece than all you had to do was fold it in half, measure top to bottom & double it, or get a piece of string & put it around the outside & again measure it. But as you have a modicum of intelligence you would already know that so I'll let you waste your money at Fensport when you could have gone to Eurocarparts.oukie wrote:The old belt was damaged, so was unreadable and I was unable to take a measurement for the same reasons.
It's not joined any ore, part of the belt was potentially missing, also, seeing as I'd already removed the alternator, I was unable to run a length of string etc,
jon_st205 wrote:Would be great to post up the size once you have received (and checked it fits) so it can be searched for by anyone in the future.
Cheers,
Jon
Will do.
Re: Alternator belt for a no1 SC
I've never had any problem with Western Toyota at Halbeath
oukie wrote:Hi does anyone know where I can get a new replacement belt for my SC with aircon, obviously there's Toyota, but with it being an import,
Chris
I've got a SC lump with the air con compressor, but i have just cut the belt off as i'll be removing the compressor. However, I can measure the belt for you if that helps?
That's because you have an n/a, Jimi, the young guy that came out to me from parts told me that Toyoyta did not make a mk1 supercharger.
Lololololololol
The belt that I used was a Gate's 5pk1030 £12 from local factors
Hope you educated him plus the really good parts guy (I think his name was Kirrill ?) has moved on
