[Mk2] [Turbo] fuel cut defender
will a fuel cut defender removed from my rev 2 work on my rev3 i am getting differing answers but need a conclusive answer
Re: [Mk2] [Turbo] fuel cut defender
No, a fuel cut defender fiddles with the MAP sensor voltage.
On a Rev 2 that's fine as the MAP sensor is only used to drive the stock boost gauge and for fuel cut.![](./images/smilies/spacer.gif)
On a Rev 3 the MAP sensor is the primary sensor used to determine fueling, fiddling with that is very dangerous.
Using fuel cut defender designed for a Rev 2 on a Rev 3 will cause the engine to run lean, resulting in engine damage.![](./images/smilies/spacer.gif)
