Those of you that already use
Fuchs Oils![](./images/smilies/spacer.gif)
will be aware of the quality of their products, especially if you are using their
Titan Race Pro range.![](./images/smilies/spacer.gif)
Well, we are pleased to inform you that
Opie Oils![](./images/smilies/spacer.gif)
are offering
15% off ALL Fuchs Titan Race Pro S and Pro R engine oils!
Be quick, this is for a
limited time only.![](./images/smilies/spacer.gif)
![Image](https://www.opieoils.co.uk/images/upload/fuchsforumimagefinal.jpg)
To get this discount, all you need to do is use the code: TITAN at checkout!![](./images/smilies/spacer.gif)
Unfortunately, your forum discount
cannot![](./images/smilies/spacer.gif)
be used in conjunction with this.
One of the most popular choices in this range is the
Fuchs Titan Race Pro S 5w-40![](./images/smilies/spacer.gif)
Originally, 5 litres of this
was
£47.95![](./images/smilies/spacer.gif)
but with the discount it is
now
£40.76!![](./images/smilies/spacer.gif)
Another very popular viscosity is the
Fuchs Titan Race Pro S 10w-50
- this
was
£51.95![](./images/smilies/spacer.gif)
for 5 litres, and is
now
£44.16!
Fuchs engine oils meet the latest and most demanding specifications set including the latest ACEA C1, C2 and C3 low SAPS approvals.
are official distributors for this prestigious brand, so if your vehicle is getting fast road use, track days, or competition use, we've got you covered whatever your set up or level of modifications!
Every oil you will find in this Titan Race Pro range including the Pro S and Pro R oils, is a fully synthetic, ester based high performance engine oil providing optimum protection for extended engine life and reliability
- with the added bonus of having
15% off!![](./images/smilies/spacer.gif)
Simply click
HERE![](./images/smilies/spacer.gif)
to see the entirety of what we have to offer, including
0w-20![](./images/smilies/spacer.gif)
5w-30![](./images/smilies/spacer.gif)
C3 5w-30![](./images/smilies/spacer.gif)
10w-40![](./images/smilies/spacer.gif)
10w-50![](./images/smilies/spacer.gif)
10w-60![](./images/smilies/spacer.gif)
15w-50![](./images/smilies/spacer.gif)
and even
20w-50![](./images/smilies/spacer.gif)
which is perfect for a classic performance engine that has been rebuilt.
Once again, that code is:
TITAN
There is an array of benefits to be gained from using these fully synthetic ester based oils, some of which include:
- Enhanced anti-wear properties
- Outstanding temperature protection and cold start characteristics
- Suitable for use in turbocharged and normally aspirated diesel and petrol engines
- Increased fuel economy
- Reduced emissions
- Ester content creates surface-active layer, meaning a thin layer of oil on the surfaces at all times
Looking at getting your gearbox or differential oil changed too? Well, you'll be pleased to hear that the
Fuchs Motorsport range![](./images/smilies/spacer.gif)
includes several Titan Race gear and diff oils too! You will find them
If you need any filters for your vehicle, follow
THIS LINK![](./images/smilies/spacer.gif)
and enter your vehicle details to find the OEM quality filter for your specific vehicle.
We also offer specialist filters from
K&N![](./images/smilies/spacer.gif)
HAMP![](./images/smilies/spacer.gif)
Honda Genuine![](./images/smilies/spacer.gif)
Mitsubishi Genuine![](./images/smilies/spacer.gif)
Nissan Genuine![](./images/smilies/spacer.gif)
and
Subaru Genuine![](./images/smilies/spacer.gif)
If you need a bit of advice on choosing the perfect oil for your particular vehicle, give us a call on
01209 202 944![](./images/smilies/spacer.gif)
Monday to Friday, 8:30-5:30 or drop us an email to
[email protected]![](./images/smilies/spacer.gif)
and we can provide a free bespoke recommendation for you.
FYI
- We would highly recommend getting your orders in
ASAP![](./images/smilies/spacer.gif)
as we will be getting very busy over the next few weeks
avoid the Easter rush!
If you require more information on the benefits of using fully synthetic oils such as these, feel free to have a look through one of our technical documents, simply follow
That's all for now folks!
- Oilman
