[Mk2] [Generic] o.e. sub - anyone done a direct replacement
acf8181
Post by acf8181 »
Just wondering if anyone has done an upgrade in the standard box?
madbasshunter
Re: [Mk2] [Generic] o.e. sub - anyone done a direct replacement
Post by madbasshunter »
Like this
5.25" woofer with mdf adapter
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
Pauln
Post by Pauln »
or this direct replacement:
I lined the stock enclosure inside and out with Vibe sound deadening material to try to lower the resonant frequency of the plastic enclosure, and then fitted a Vibe Slick 5 speaker.
Paul
acf8181
Post by acf8181 »
and are you both running off o.e. amp, or an aftermarket?
Pauln
Post by Pauln »
I've fitted a small Kenwood sub amp in the frunk connected to the line level sub output on my head unit.
This enables me to roll off higher frequencies to try to get the best out of what is quite a small sub unit without having to drive it too hard.
It looks like madbasshunter is using a PYLE PLG54 in his oem sub enclosure.
Paul
madbasshunter
Yes it is a Pyle PLG54 Paul
I ran it off the factory amp (so at half power as 4ohm load not 2ohm), it was only run for a few minutes as a trial before I put this in
as I like more bass than a 5.25 can manage
The amps are in the boot
but are removed at the minute as I have a bigger amp going in for the sub 1000w rms at 1 ohm instead of the 500w rms one
acf8181
Post by acf8181 »
Got one of those pyle subs, but not good running it on o.e. amp
Would an aftermarket amp fit under a seat does anyone know?
2mad
Post by 2mad »
madbasshunter wrote:Yes it is a Pyle PLG54 Paul
Mega stuff mbh :) .. love your work :thumleft: .. stock alternator??
Pauln
Post by Pauln »
acf8181 wrote:Got one of those pyle subs, but not good running it on o.e. amp
I think you's struggle to find an amp thin enough to fit under the seats, there's really not much height there. Plus it's always a good idea to make sure air can pass around the amp.
Most people seem to fit amps on the rear firewall in the cabin or in the frunk.
Paul
2mad
Post by 2mad »
Paul
I fitted an amp .. an apline 3539 under one seat and vibes biggest amp under the other .. plus a big power cap and 5.50" iirr vibe front and rear .. sounded mad with a alpine type r sub in the back .
Be creative mate :thumleft:
acf8181
Post by acf8181 »
So there's plenty of room then 2mad?! :shock: :lol:
Won't be anything like as adventurous for me, smaller the better!
2mad
Post by 2mad »
acf8181 wrote:So there's plenty of room then 2mad?! :shock: :lol:
Mine fitted .. maybe a little scrap on the vibe amp .. not a problem ... had pic or two on my old laptop but it died :(
My amps were pretty big and they went under the seats ok .
Pauln
Post by Pauln »
Just goes to show how wrong you can be :lol:
I had originally hoped to fit my small Kenwood sub amp under the seat, but just couldn't make it fit without jamming when the seat slid backwards. I should have bought a Vibe, and saved myself a lot of work.
Paul
2mad
Post by 2mad »
Pauln wrote:Just goes to show how wrong you can be :lol:
Paul
Not sure if that was sarcasm Paul .. but my alpine 3539 and vibe under the passenger seat fitted fine .. maybe a little scrape on the vibe , nothing magor though 8-[
Pauln
Post by Pauln »
No it wasn't sarcasm, not my style.
I bought a Kenwood amp in he hope that I could fit it under the seat, but no matter how much I fiddled with it I couldn't make it work. So ended up having to make a suitable panel and fit it in the frunk, which with my very basic woodworking skills took a lot more time to sort.
Sorry if I came across badly, I didn't mean to.
Paul
2mad
Post by 2mad »
Pauln wrote:No it wasn't sarcasm, not my style.
Paul
Aw my bad sorry mate .. my amps are quite big but very low profile so just fitted with a little scrape .. wish i still had the pics put alot of work into it .. ill see if there still on my old phones memory card , never know .. sorry again :oops:
madbasshunter
I fitted a turbo alternator and added 0gauge wiring to it 2Mad
Have always found under the seat very shallow on the mr2, I did try fitting a vibe optima underseat sub
but it lifted the seat so it couldn't be bolted down
2mad
Post by 2mad »
0gauge wiring ftw mbh :thumleft: .. nice :D
Return to “ICE and Security”
