[Mk2] [NA] Standard Alarm Problem. Help Please
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security
Author Message
david240968
PostPosted: Fri Mar 07, 2014 12:25 pm    Post subject: [Mk2] [NA] Standard Alarm Problem. Help Please Reply with quote Reply with quote including images
I have a rev 5 and the factory alar keeps setting itself off for no reason. I have to disconnect the battery to stop the alarm. I've had enough of it now and thought of just cutting the alarm siren out of the car.
Would it be ok to just cut the wires off the siren and would it cause other issues? [thumleft]
Back to top
User is offline
Peter Gidden - SBITS
IMOC Affiliated Company
2002 Noble M500
PostPosted: Fri Mar 07, 2014 12:43 pm    Post subject: Reply with quote Reply with quote including images
You're better off unplugging the alarm ECU.
_________________
Engine Builder to Simon Hicks - 555bhp 532ftlbs
Brighton National Speed Trials Class Winner 2011
Brighton National Speed Trials Class Winner 2010
Brighton National Speed Trials Class Record Holder 2010 on
Back to top
User is offline
david240968
PostPosted: Fri Mar 07, 2014 1:03 pm    Post subject: Reply with quote Reply with quote including images
That sounds easy. Where is the alarm ECU and is it as simple as unplugging it? Thanks
Back to top
User is offline
Draven
PostPosted: Fri Mar 07, 2014 2:43 pm    Post subject: Reply with quote Reply with quote including images
I'm pretty sure its behind the stereo.. if you dig around behind there there is a little box. I did have a photo somewhere.
[clown]
Back to top
User is offline
david240968
PostPosted: Sun Mar 09, 2014 10:56 am    Post subject: Reply with quote Reply with quote including images
The alarm is really playing up now. Goes off for no reason and the only way to stop it sounding is to disconnect the battery. I got to the siren but couldn't release the connector. If I just cut all the wires of the siren will this work. I'm worried about the car not working if I do this. Urgent help please as it's a right royal pain in the ar$e right now.
Back to top
User is offline
Draven
PostPosted: Tue Mar 11, 2014 3:12 pm    Post subject: Reply with quote Reply with quote including images
As I said pull the ECU of the alarm is is located behind the headunit.
Car should still start and work fine. but the alarm won't work at all.
Back to top
User is offline
platmatt8
Premium Member
PostPosted: Wed Mar 26, 2014 8:27 pm    Post subject: Reply with quote Reply with quote including images
Under the front passenger side wing is the alarm siren. This will be full of water and corroded.
Either attack it by removing the head light or from underneath.
The central locking will still work and lights still flash but not sound.
Back to top
User is offline
Herts66
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Tue Mar 03, 2015 7:01 am    Post subject: Alarm disconnect Reply with quote Reply with quote including images
Hi I have a similar issue with my Rev4.
Driving or stationary with the engine running the doors randomly lock
And the alarm sets and activates
The siren gave up the ghost years ago
What's best pull out the radio and disconnect the
Alarm ecu or replace the siren module
Under the nsf headlight?
If I disconnect the ecu does the central locking still work
Off the fob?
Back to top
User is offline
Herts66
PostPosted: Sat Mar 21, 2015 12:36 pm    Post subject: Reply with quote Reply with quote including images
Mine was the accessory fuse. Shorted when the satnav fag lighter plug broke when I plugged it in.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security All times are GMT
Page 1 of 1
Jump to:
