Hi All,
Well im am terrible when is comes to I.C.E so bare with me hear.
Lately everytime i turn the stereo on a loud high piched Eeeeeeeeeeee noice come out the passanger door tweater.
When the car is ticking over and you slighlty rev the engine the Eeeeeeee noice goes up and down with the revs???
Weird!
Any ideas?
Cheers Craig
[Mk2] [Turbo] I.C.E problem (HELP)
Re: [Mk2] [Turbo] I.C.E problem (HELP)
Sounds like alternator whine to me.. you haven't put amps in the boot have you?
There are 2 amplifiers in the Frunk!
Could be an earthing issue??
Craig
Craig
CRAIGROBBO wrote:There are 2 amplifiers in the Frunk!
Craig
It could yes generally the whine is caused by the alternator perhaps try shortening the earth wire from the amp or try earthing to a different location. Or if it is in the frunk earth directly to the battery.
Hi All,
Thanks for the replys...
Traced the earth back to the battery and the terminals were all corroded.
The earth lead was 3 times as longs as it needed to be.
Made a new short earth cable with new ends and touch wood it all seams to be working fine!
Cheers Craig
Cheers Craig
