6 speed LSD Mk1 gearbox build
PW@Woodsport
Re: 6 speed LSD Mk1 gearbox build
Post by PW@Woodsport »
Interestingly the new 4.312 FD ratio for the 6 speed takes the theoretical top end speed up to 144mph v 128mph on the 5 speed, assuming the 4a-ge has the power to get it there.
gon
Post by gon »
no prob, thank you Paul for all your contribution, including this thread.
I have pictures of the crown and pinion of the c52 and of the c64 (celica T sport) if anybody fancies counting teeth I can put them up.
The C64 (celica and corolla T sport) does have a 4.53 final ratio
I am attempting to put the gear ratios of the C64 inside a C52, and keeping the mk1b driveshafts, for that I am trying to swap the spider gears inside the open diff... let us see how that goes ....
PW@Woodsport
Interesting idea swapping the spiders, wouldn't it just be easier for you to run a pair of Mk2 shafts though?
That really is job done and they are stronger than Mk1 shafts.
gon
Post by gon »
It would be, but budget is reallyyyy tight now...
I will see if I can get the clearances right, if not I will have to spend another 100 quid on them shafts ... but then if I already have the shaft I would probably get the mk3 lsd .... and the missus will not be happy at all :mrgreen:
PW@Woodsport
Who is in charge of the Mk1 knowledge base these days?
Peter Gidden
Post by Peter Gidden »
PW@Woodsport wrote:Who is in charge
wassat?
:mrgreen:
The Silver Fox
Post by The Silver Fox »
Paul,
I have no technical knowledge of gearboxes but given that your long fifth gear mod also has a ratio of 0.725, what are the differences in performance between the boxes? Am I correct in assuming the six speed box will give better acceleration?
jimi
Post by jimi »
Excellent write up Paul :thumleft: Do you mind if I copy it it for KY2 ? Credited to you of course :)
stenky
Post by stenky »
The Silver Fox wrote:Paul,
The contribution of this gearbox is twofold. Gears 2,3,4,5 provide better performance due to slightly shorter gearing. Namely its +7,7%(2nd) +13,1%(3rd) +20,3%(4th) and +12,4%(5th) torque to wheels increase over C52.
6th retains highway cruising efficiency as the fifth 0.725x4.312 mod.
Basically a win-win situation. Performance without compromising fuel consumption (not that I cared about this much).
PW@Woodsport
jimi wrote:Excellent write up Paul :thumleft: Do you mind if I copy it it for KY2 ? Credited to you of course :)
Yes by all means Jimi fire away mate, i'm trying to get it added to the Imoc KB but not much response yet..... Imoc seems to be a ghost ship with nobody at the helm these days! :D
Thankyou for clarifying Stenky.
jimi
Post by jimi »
Cheers Paul, it's done http://www.mr2oc.co.uk/know-your-2-know ... bartid=272 8)
stenky
Post by stenky »
yay, my gearbox is going to be famous :D
coanda
Post by coanda »
Thanks for taking the time to share this with us Paul - will come in handy in the future considering how far away I am from Woodsport.
Any problems with the 4agze?
PW@Woodsport
I've been asked that a few times, in terms of fitting the gearbox to the engine it will fit, the SC shafts won't work though, they would need to be Mk1 for non LSD or Mk2NA for LSD.
What isn't clear is wether a SC has the same gearbox mounting position, i always presumed they were the same but when i came to put a SC engine into a Mk1 NA one time i had to modify the mounts.... so i'll have to say yes it will fit but might need torque mount mods.
MartG
Post by MartG »
IIRC The rear torque mount on an SC has, in addition to the two bolts that go vertically up from below, two bolts that go horizontally through the crossmember :-k
PW@Woodsport
Thanks Mart, i knew about the extra bolts, but i also think the torque mount relative position to the gearbox is also different, i think it's because the SC box is E series based and Mk1 NA box is C series.
PW@Woodsport
Back to my question earlier last week, who is in charge or has access to the Mk1 Knowledge base? I think this article has enough merit to be added instead of it disappearing off list into the archives.
stenky
Post by stenky »
Looks like censorship>>expanding KB
I am sooo getting punished for this, but phuket :eye:
elbon50
Post by elbon50 »
PW@Woodsport wrote:Back to my question earlier last week, who is in charge or has access to the Mk1 Knowledge base? I think this article has enough merit to be added instead of it disappearing off list into the archives.
I would suggest PMing Lauren or Chris (Limey) about that Paul
cartledge_uk
Post by cartledge_uk »
You can add it yourself paul
see this thread
http://www.imoc.co.uk/forums/viewtopic.php?t=76755
Or I can for you if you want :thumleft:
