About £4k for the engine and one of Gouky's fitting kits. All the labour I'm doing myself. Mines a turbo so all the driveshafts, gearbox etc get reused. Just need to buy a new clutch and flywheel to fit.
I think all in 5k is a fair price.
Best v6 or v8 to buy?
Re: Best v6 or v8 to buy?
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
sounds good
Race Idiot wrote:Just out of curiosity i'd like to know what you did with the accelerator pedal, seeing as the 2gr is dbw. I remember reading the first thread with the guy, gouky i think? but I forgot what he did to get around the dbw issue.
You use the original DBW throttle pedal and mount it in the footwell with a bit of bracket fabrication. Just run a cable from the pedal back to the ECU.
The nice thing is once I figure out why the ECU doesn't like the original speedo feed from the clocks (which it should) then the cruise control within the ECU can be used. As it controls the electronic throttle body.
Also for folk worried about DBW I wouldn't be as it's impossible to tell it's not an analogue throttle.
jasongtr wrote:supercharged 2gr - anyone got one or doing one
Turn the volume down before clicking the link:
http://www.youtube.com/watch?v=pWPh54-0H8A
We've done another one since and there are two more superchargers currently winging their way from Australia to us right now.
I guess they're the TRD units from the Aurion if they're coming from Oz?
Rogue wrote:jasongtr wrote:supercharged 2gr - anyone got one or doing one
whats the dyno figures then
Marf wrote:I guess they're the TRD units from the Aurion if they're coming from Oz?
You got it, exactly the same kit that's on the Evora S as well - although they powdercoat the Harrop HTV1320 black rather than red.
jasongtr wrote:whats the dyno figures then
...and here's a comparison of the same car on the same dyno before and after supercharging.
200lbft at less than 2000rpm, and a really nice power curve, very linear.
What's one of these chargers cost?
Marf wrote:What's one of these chargers cost?
You're looking at the thick end of £5k for the complete kit.
Is that for the Charger, injectors/fuel rail and ECU?
dbl post
Rogue wrote:Marf wrote:What's one of these chargers cost?
Yowzer.
So you'd be looking at the thick end of £10k for a 2gr and one of these
uglee wrote:Is that for the Charger, injectors/fuel rail and ECU?
Go on Lee, you know you want to. First refusal when you sell your car too
Expensive horsepower
This is a stock 2gr with Link ecu, exhaust, intake. 278rwhp.
That's for the supercharger, injectors, cast aluminium inlet manifold, brackets, oil pipe, bearings and belts. There's no ECU with the kit and I suspect the stock 2GRFE was reflashed with a specific SC map.
Al-sw20 wrote:Expensive Horsepower
Is there any other kind?
I consider the TRD supercharger route to be currently the most economical route to the power figures it achieves. Don't get hung up on peak figures either - the vastly larger area under the curves means that the supercharged car would be well ahead before you've even hit max horsepower.
