I've read and heard about a few people considering doing this to various Turbo cars. apparently it'll increase power but decreases reliability.
Anyone heard of this and can you explain it? I guess the air has a free'er flowing path in and out of the turbo.
Turning turbo 90 degrees
Parts For Sale: KAAZ diff:http://www.imoc.co.uk/forums/viewtopic.php?t=115584 HKS Fuel Rail:http://www.imoc.co.uk/forums/viewtopic.php?t=115585 50mm Wastegate:http://www.imoc.co.uk/forums/viewtopic.php?t=115586
Re: Turning turbo 90 degrees
i would imagine that rotating the turbo a few degree's towards the rear of the car, was done so that the IC pipe from the turbo is further away from the hot exhaust and shield.
Not sure that this would be easy to do though without mods to cooling and oil lines to turbo not to mention wastegate actuator, and Intercooler.
Chris
Chris
Not nessacerily on a 2.
I know of a couple of scoobies thinking about this. Plus plenty of yanks.
turbo can b turned through 360 if u want to but its no worth it on a 2 i had to rotate mine wen i fitted the high end supra turbo which pulls all to 7k woohoo
