Hi
On mway this morn got bad vibration - stopped and left front wheel very hot. This is obviously a siezed caliper but my question is is it likely to have warped the disk?
Alistair
Siezed Caliper
Re: Siezed Caliper
Same thing happened to me last week, vibration was really bad, thought a wheel was falling off! Stripped the caliper right down, one piston had seized, gave it all a good clean, seems ok now and luckily I didn't warp the discs, and there was smoke coming out of the front wheels when I got home. Discs are cheap enough anyway.
Re: Siezed Caliper
Could be wheel bearing
- Lauren
- IMOC Committee
Re: Siezed Caliper
832ARK wrote:Hi
Alistair
If your brake pad has worn out due to a seized caliper then you may have scored the disc badly in which case you would probably need to replace it. You won't know till you whip the wheel off and get a good look at the disc.
Siezed caliper
I have dismantled front brakes on Mk2's umpteen times to free off frozen or sticky caliper pistons but after a while the problem re-appears and the only long term solution is to replace the whole caliper, either with a new or reconditioned item. Why is it the front's always go sticky on MK2's and the rears on MK1's? If left unattended, I have heard of wheels completely locking up causing 180/360 degree turns mid-motoring, or of tyres blowing out from the excess heat, so watch out!
Re: Siezed Caliper
i got away without the disc warping when this happened on my old turbo. but don't think you can just get away with unsticking the seized piston. it will only seize again. get a refubed exhange from brakes international.
832ARK wrote:Hi
Alistair
Re: Siezed Caliper
Thanks for all your help, ordered a refurb caliper yesterday but freed off the siezed piston so i can drive it till the weekend. Havibg driven it today i found that the disk had warped so have ordered disks as well. Are the disks from barkes int any good as theuy seem well cheap.
Alistair
Alistair
Re: Siezed Caliper
Discs from Brakes International are excellent quality manufactured in Germany.I have them all round.
