There is also the upper steering shaft which can cause knocking going over bumps.
It is caused by wear on the universal bush for the steering tilt mechanism.
The wear creates float along the length of the shaft which gives rise to the knocking.
The fix is simple, permanent
(and free)!!
1.
Raise the front of the car onto axle stands.
2.
Remove the lower panel beneath the steering column
3.
Grab the
(now visible) steering column and shake it longitudinally
(ie along its length).
If this produces any sort of knock similar to that heard when driving continue
(otherwise stop and put everything back as the knock is caused by something else)
4.
Remove the two piece cowling which covers the indicator and wiper stalks.
This will reveal a white
two-piece nylon bushing on the upper steering column which can only be viewed from beneath.
An exploded picture of the column is given on this link:
http://www.mr2-tech.com/bgb/mechanical/ ... eering.htm
Page SR-7
(The nylon bushing which is worn is at the
'arrow' pointing at 4 o'clock between the words
"Bearing" and
"Main Shaft")
5.
If you now grab and rattle the steering column in the same way as before you will see that there is a small amount of float in this bushing which coincides with the knock.
It is as if the two pieces of nylon part and come back together as the column is rattled.
NOTE that if you unlock the tilt mechanism the gap between these pieces of nylon broadens.
6.
If you now turn the wheel you will see that the
two-piece bushing turns on the column and in fact is four lots of
two-piece bushings.
Taking up the float in the bushings is the key.
I solved this by using
(believe it or not) household
or parcel string.
Unravelling a short piece into strands allows in to be pushed between the pieces of nylon bushing with a very fine screwdriver.
Turn the wheel to expose another quadrant bushing and push more string fibres into the gaps.
I then applied some silicone sealant with my finger to prevent the string from coming back out.
Locking the tilt mechanism to the preferred angle at this stage is advisable.
I was able to put strands of string into three of the four gaps in the bushings.
The forth one had no slack left after Id put string into the other three.
7.
Grabbing the column at this stage and trying to rattle it will prove the knock has stopped.
I did fix more than two years ago and there hasnt been any knocks over any bumps since that day.
I thought it would have been a short-term fix but it has turned out to be permanent.
I have never altered the
tilt-mechanism since out of fear that it might affect the string.
Sorry but as I did the repair a while back I don't have any photos.
