I've just taken the rotten exhaust of my 1987 mk1b.
There is a large metal
Also, what sort of rustproofer would people recommend?
http://www.bilthamber.com/index.html
There are rust removers, rust preventers, paints and waxes.
Widster
Adam W wrote:I just took those heat shields off my car and every single bolt snapped.![]()
Don't expect to refit them unless you drill out the old bolts and retap all the threads!
coverco wrote:Adam W wrote:I just took those heat shields off my car and every single bolt snapped.![]()
50% of mine sheared, they are pigs to drill and tap as well as the swarf falls onto you![]()
I did my heat shield with POR15, the boot floor on mine was OK but I wire brushed it and used Hammerite on it, all that work and you can't even see the thing once the exhaust is back on![]()
widster wrote:coverco wrote:Adam W wrote:I just took those heat shields off my car and every single bolt snapped.![]()
Think i might just leave it in place and hope that the boot floor is solid!
