A little advise from anyone who has some
Cheers Very Much!
Hope this helps and if your happy with standard pads I do em at 25% at www.flashmetal.com ;-')Page 138
Cross Drilling
Unless your using period-correct brake pads that release gasses when hot, cross drilled rotors dont improve performance.
Cross-drilled rotors were invented when brake pad compounds released gases when they were hot (a phenomenon called outgassing). The gas pressure actually pushed the pad away from the rotor surface. Cross drilling allowed a passage for the gasses to escapr. Modern brake compounds usually dont release gas under load, so you usually dont need cross-drilled brake rotors. Some high end car manufacturers have cast cross-drilled rotors alomg with painted calipers, but this is done more for marketing than because it improves performance.
If rotor holes actually are drilled instead of cast (this includes most cross drilled aftermarket rotors), the rotors are prone to cracks, and ultimately failure around the drill holes.
Slotted Rotors
A grooved or dimpled rotor surface may make brake pads less likely to glaze (crust over with burned material) under high heat. But these features are more of a marketing gimmick than a benefit ro the performance-minded enthusiast. They look cool, but grooves and dimples work like a cheese grater on the brake pads, wearing them more quickly than a smooth surface rotor.
If your rotors are glazing over, the culprit probably is your brake pad compound. You will be better served changing to a more aggressive pad compounds rated for a higher heat range.
